Yes I’m referring to the lift capacity. I measured at the quick disconnect for the bucket curl. No rear remotes. Use to easily lift buckets of dirt and gravel. Now won’t do more than about 1/3 bucketAre you referring to a loader lift capacity?
Do you have any rear remotes?
A rear remote stuck on with a detent can drain all the pressure available to the loader.
Where did you measure the pressure? Do you have both the tractor and loader WSM as you need to fully understand the hydraulic circuit to decide where to take a measurement as it may be different with and without a loader.
The loader is on the tractor and has never been removed. It seems to affect both lift and curl. I have a box blade on the back and it does seem to raise slowly. I can check a lift circuit this afternoon instead of the curl functionRight now I cannot find a WSM for a L2501 nor a LA525 lA525 loader.
Is this the loader on your tractor?
Do you have any manuals besides the Owner's manual?
Be patient with me and do not go pulling things apart.
Can you do the pressure test on a loader arm circuit?
A common mistake is for owners to get frustrated and start opening valves and blowing compressed air around try to figure things out,
Do you feel both the lift arms and bucket movement are affected or just the bucket
Do you ever lift anything on the 3 pt so as to know if it is affected too?
Did any hoses get changed lately?
Has the loader been off and then re-installed?
Does the loader valve stay on the tractor when the loader is removed or does the valve come off with the loader and then you connect a bypass hose?
Has a 3rd function kit been installed?
How many hoses are attached to your loader valve. 6 or 7?
Recently a B2400 owner was getting very frustrated and in the end a quick coupling had failed internally and was causing weird hydraulic actions.
Dave, not sure if this helps any but here is a couple pics of the LA525 loader valve in question. (7 hoses)Right now I cannot find a WSM for a L2501 nor a LA525 lA525 loader.
And I really appreciate your efforts in doing so.Sorry Dave, I was just added that to give you a visual of OPs setup.
I’ll give it a try. ThxIf 3 pt is fully raised & feedback rod isn't adjusted correctly then 3 pt relief valve can be unseated causing lower hyd system pressure. If you can hear a hissing sound at 3 pt control valve move control lever forward a little until hissing noise stops. Also disconnect/reconnect all quick couplers for FEL
i did get to check the lift circuit this morning and all reading at still 1000 psi. No hissing on the 3pt hitch. There are seven hoses on the FEL. Three are threaded and 4 are quick connects. Thinking about changing the filter and oil again before going furtherAnd I really appreciate your efforts in doing so.
Will teach me to read everything and not skim
You did not answer my questions regarding the filters and fluids used. Is there some related reason why you are going to change fluids and filters again.?I’ll give it a try. Thx
Changed with Kubota filters and mostly Kunitz ud2 hydraulic fluid. I say mostly because I did run out and topped it off with what is advertised as a comparable fluid. Just thinking maybe a problem with the filter or somethingYou did not answer my questions regarding the filters and fluids used. Is there some related reason why you are going to change fluids and filters again.?
