Need hydro advice on adding 2 sets of rear remotes to a cab model LX, please. New to tractors and didn't think I'd need them when ordering the machine. Got a box blade and only recently discovered "top 'n tilt" and of course I gotta have that now. Priced parts from Kubota and they're crazy expensive, even if using my labor. Looking at Summit Hydraulics' Z-50 Monoblock Solenoid Directional Control Valve, 2 Spool. Will this work? Where would you mount it? I have the Kubota third function valve so I need to find a P port somewhere to get pressure to it. The return line from the 3FV looks like a hard line with a banjo fitting to the axle; would I get a similar banjo fitting and stack them using a longer bolt? Thanks for any help!
