The ROPS GRAY ,would look the closestWhich color do you think you have. https://www.messicks.com/Kubota-Paint-Chart
The frame and ROPS may not be the same color originallyI have a 2003 Bx1800d,looking for what I call the gray paint ,but see it advertised as blue.what is the color of frame and roll bar?
I’m finding that out as well.Tractor Supply has the aftermarket for the Orange, but I have not found the ROPs Gray. It appears to be a unique color.
Your tractor is the Gray, not the Blue as it has not been used since 1989 or so.I have a 2003 Bx1800d,looking for what I call the gray paint ,but see it advertised as blue.what is the color of frame and roll bar?
Im with you brother! Tractor supply hasnt had Kubota orange since last spring!Absolutely Kubota has the correct color paint, but I have not found it aftermarket. I ain't paying $16 for a rattle can of any color paint.
The can spray is expensive, but good quality. I have a few cans but 90% of the time I catalyze factory acrylic enamel paint. I try to use a sponge brush when possible, because spraying ISO’s is so bad. You can’t beat factory paint for the match and quality. Buy paint for a car and you will know what expensive is. I want my tractor paint to match, be harder than powder coat, and not fade any faster than the rest of the unit. One gallon lasts me years.Absolutely Kubota has the correct color paint, but I have not found it aftermarket. I ain't paying $16 for a rattle can of any color paint.
The isocyanate hardener for alkyd enamels is much safer to work with than what is used in urethane finishes. It is safe to spray with a cartridge type respirator as long as you have some ventilation. The hardeners for urethane's is what you have to have an air supplied respirator to use.The can spray is expensive, but good quality. I have a few cans but 90% of the time I catalyze factory paint. I try to use a sponge brush when possible, because spraying ISO’s is so bad. You can’t beat factory paint for the match and quality. Buy paint for a car and you will know what expensive is. I want my tractor paint to match, be harder than powder coat, and not fade any faster than the rest of the unit. One gallon lasts me years.
My TSC has plenty of it. It can also be ordered online.Im with you brother! Tractor supply hasnt had Kubota orange since last spring!
