Hello Friends,
I'm a bit perplexed and I think my memory has failed me. Fellow 2601 owners tell me about 4wd! Something is messed up and I'm not sure if it's my memory or the tractor? When in 4wd (Front wheels in 4wd by the placement of the lever) both front wheels are connected to the drive train and supply power to BOTH wheels in either forward or reverse! If either tire is off the ground or loses traction the opposite wheel continues to drive on under power.
The reason I am asking or stating this is, my tractor when in 4wd, on the flat ground both front tires pull me along. If one tire loses traction because of loose ground or it is off the ground it begins to spin fast and the wheel that is still in contact with the ground provides no power to keep the tractor moving!
I want to say when my tractor was newer I had power to both front wheels regardless of rather one wheel was touching the ground or not. If one lost traction the other continued to pull me forward. Is that correct?
I understand the locking differential! A locking differential when engaged "LOCKs" both axels together and power is sent to both wheels. If one wheel loses grip the other still has power. When the differential is unlocked, each wheel can spin independently.
A limited-slip differential sends more torque to the wheel with traction and the opposite wheel has some loss of traction.
Is my B2601 a limited-slip diff or a locking diff when the lever is in the 4wd position. I have disassembled the front axel, nothing is broken or wrong with it. What's the truth? Should my two front tires be locked up when in 4wd, should the trie that is in the air spin freely and NO power go to the other wheel that is still in contact with the ground?
Help me remember! My tractor used to climb hills like nothing, now is one tire loses traction I am done. We are not talking about the locking read Diff here. Just the front!
Egressman
Egressman
