Hey, everyone!
Have a problem with my B2650 w/HST and 3rd function valve kit installed. I get a spraying hydraulic leak from the elbow connected to the tank port whenever I lift with the 3-PTH. It is a serious stream when an implement is attached; it splashes the driver side tire. One of the lines to the 3rd function valve is attached to the port where the elbow is connected. I do not have anything attached to the front of the tractor and am not utilizing an implement that requires the third function valve when the leak occurs. Have tried tightening everything with no luck. The leak appears to be coming from around the top of the nut attached to the elbow. The next step is to take it to the dealer unless someone has an idea.
Thanks in advance!
Signed,
Frustrated Radar Tech Who Drives a Kubota
Thanks in advance!
Signed,
