Reviving this as my set up has changed since this original post (and seems like parts of this thread was lost in the site crossover).
Had to do away with the rear lights after I added the backhoe because the fender support they are mounted to is removed to clear the back hoe seat. Not sure yet if I will keep the 2 small lights for the rear or swap out for the light bar I got laying around.
I also needed to finish the wiring for my sprayer. The project box I have for the switches, fuses, and relays had no more room left to add the sprayer circuit. So time to re think all this.
Got an auxiliary fuse/relay panel to help with this. Had planned on putting it under the dash panel but there wasn’t enough room.
Ended up mounting it to the back of the fender (don’t mind the wiring mess yet)
It comes as a bare box with bags of teminal ends.
Getting the box wired up if very tedious.
Will hopefully finish it up tomorrow.
(Dont mind the dirty tractor
Couldnt get it washed before I started
