i7win7
Get the most benefit from your quick hitch. Buying new get QH compatible. Here is a photo of an implement whose manufacturer has their act together. Note how it's designed for cat 1 & 2. Also the lift arm spacing can be adjusted.
Some "QH compatible" only need minor modification. This TSC rake, come on TSC is it really compatible without a parking stand? I drilled holes for a bearing block and added 1" water pipe and flange.
This 6' Land Pride blade even has a quick hitch label. The problem, top link hole is set too far back. Buying a longer top link hook solves this problem. The faster cure, grab an angle grinder, cut off wheels and remove about 3/8" of steel from top link area.
King Kutter makes a 4'XB tiller - must be a sub cat 1. Purchased longer implement pins and spacing washers. The top link bushing was in the rear hole, moved to front and used bolts for rear supports.
Moving on to ballast box. I purchased a Titan box off Amazon. The top link hole was not in the same vertical plane as the lift pin holes and it was set too high. I used a QH top link adaptor in a unique way. Drilled new holes for top link pin.
20200705_134546
Recommend a solid storage stand, you can back under ballast without knocking it over.
Let's up the mod game and fix RK/King Kutter subsoiler and middle buster. In the photo below you will see I run the top hook in the lowest holes. The easy fixs to raise the top hook by two holes - then everything else doesn't fit. First thing to do is create an adapter pattern. Trace the shape of the hook, attach implement and drill it's top link pin holes.
20200705_134546
