Sure they do - now getting the filter on the shelf might be an undertaking.What about filters? Does fram for instance make filters for Kubota sold at Wally for instance?
Thanks a lot for that good Samaritan, I will put it my favorites!!!Sure they do - now getting the filter on the shelf might be an undertaking.
FOR your machine ........... here is a cross reference for any filter that will "fit" .......
I would keep the ol KUBOTA on there myself!. I use Baldwin filters and Wix filters on my B7100's.
Yes, think I will, Have used Fram for decades and don't quite buy it. Some places they are the only filter available except off brands. but hell, what do I know.In the automotive world, Fram filters are the butt of jokes about their cheap quality and general ineffective filtering performance.
being as how Kubota is getting ornery about warranty claims, you might want to use genuine filters for now.
Kubota cannot deny a warranty claim based on the brand of filter or the oil that you use, provided that the oil meets their printed requirements for grade and the API symbol is correct for that engine.The Magnuson-Moss Warranty Act, passed by Congress in 1975, is the federal law that governs consumer product warranties . The Act requires manufacturers and sellers of consumer products to provide consumers with clear and detailed information about warranty coverage.
When looking at the cross reference, keep in mind that there are only about 3 oil filter manufacturers left in the United States, and that they manufacturer for many of the brands that are listed on the cross reference, and that they also tailor the product to the price point of the purchaser. If brand XYZ wants to have an inexpensive filter manufactured so they can retail it at a specific price point, one of those 3 manufacturers will do it with lesser quality materials. If you change oil frequently then the quality of the filter will be of less importance, because the lowest quality filter will work well when the oil is fresh. It is when the oil gets dirty that the filter must start to do its job of removing contaminates from the oil. A lesser quality filter will fail sooner doing this task that the better quality filter. I have seen the video that was produced by Neil Messick, where he cuts the filters open and shows what is inside the can. The amount of filtering material isn't as important as the quality of the filtering material. For that to be determined, you can't tell just by cutting the filter apart, but only by doing scientific testing of the filter material. A filter material that filters to 100 microns is better than a filter that filters to 500 microns, since the 100 micron filter has smaller holes to catch the contaminants. The filter that the material is rated at 100 microns, might catch more contaminants, but it will also clog faster, and then the bypass spring will allow the oil to bypass the filter. Your best choice in a filter is to choose a name brand, and change the filter and oil frequently. Kubota says that the oil on my new BX23S should be changed at 100 hours, but that would be 2 years of use for me, so I change oil every 50 hours instead. On my 1986 Mercedes turbo diesel, I changed the oil and filter every 3000 miles, and I never had any engine problems. I followed the recommendations of Mercedes for all services and my repairs were minimal. Oil and filters are inexpensive compared to what it cost to overhaul an engine. It is the wrong place to skimp on quality.Thanks a lot for that good Samaritan, I will put it my favorites!!!
I have always been a firm believer in using OEM filters on all my Kubota equipment. I seen that video and it only convinced me even more.You should look up the youtube Messick video where Neil cuts into filters. Personally, the difference in price of the filter isn’t worth messing up my tractor. Diesels of all types seem to be the least tolerant of low quality filters. Unless you are really going through a lot of hours, I think you won’t notice the price difference.
There are a lot of "it will screw on there" cans out there. Usually, if you check the micron rating, bypass setting, burst strength, amount of media, etc, they do not meet the OEM spec.I have always been a firm believer in using OEM filters on all my Kubota equipment. I seen that video and it only convinced me even more.
If any of us were to design “from scratch” a new vehicle or tractor engine... would we utilize existing air filters and canisters and elements with air-flow/filtering capacity that meets our engines’ needs which someone already makes..?? Or would we also undertake to create an entirely non-existant, new design which would require additional designer/engineering input, proving-tasks, and costs... then a search for a manufacturer who would take-on an entirely new line of filters in addition to their present workload?I like to use OEM oil and hydraulic filters I do however used NAPA gold air filters.
My Exmark mower and L4600 take the same air filter, found that kind of odd.
Best of luck.
Jay
Wise man on the stocks of maintenance items. Hydrostatic trans is the tractor hydraulics...right? Some things in the owners manual are not clear or whatever. There is a language barrier there as reported on this site previously.Kubota cannot deny a warranty claim based on the brand of filter or the oil that you use, provided that the oil meets their printed requirements for grade and the API symbol is correct for that engine.
As for filters, I purchased a 2 cases of Fleetguard filters about 15 years ago, and I have been using them on my old BX22 along with Shell Rotella oil. I change oil every 50 hours, which works for 1 year of use for my tractor. I also change the air filter whenever it becomes dirty, and once again, I purchased a stock of them a few years ago, and I always have oil on hand for when I need it. I do use the Kubota filter for the hydrostatic transmission and the tractor hydraulics, since it gets changes so infrequently, that I will use what Kubota recommends. I used the regular UDT in the past, and my new machine will get Super UDT when I change it next month. Yes, it is expensive, but there is no less expensive substitute for the Kubota product that I know of.
Which seems really amazing considering their market share in the U.S.Wise man on the stocks of maintenance items. Hydrostatic trans is the tractor hydraulics...right? Some things in the owners manual are not clear or whatever. There is a language barrier there as reported on this site previously.
The tractor hydraulics power all of the tractor hydraulics including the HST. The HST is fed by the hydraulics and that fluid is filtered a second time before the HST.Hydrostatic trans is the tractor hydraulics...right?
