River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
I had a guy come out yesterday and drop that sketchy ash along with a nearby maple that was also damaged and another problem tree.
I then took over with the clean up. The Ego saw, the Husky 50 and the Kubota are all getting the job done.
Cutting it all into rounds and dumping them in a pile out back so I can rent a splitter and get my money's worth.
The heaviest section of the ash was cut to about 20' and I laid out some 4' logs and hooked it up tot he tractor to create a nice log roll......worked like a charm. Then gave the Husky a workout bucking that up.....
I have been impressed with the 2601 pulling out logs, hasn't even begun to struggle or break traction.
Loader 2.1.jpg Log Flume 1.1.jpg Skidding 1.1.jpg Tree 1.1.jpg Tree 5.1.jpg Tree 6.1.jpg
Seppe906
LX2610 ROPS with LA535 FEL, BH77, 60" MMM
Mar 27, 2021
UP Michigan
Found a power pole (or telephone pole) in the river and used the 180° BH swing to pull it onto the trail, it'll make a nice flagpole! Then got the tractor stuck :confused:, should have known better, pretty soft ground. Good learning experience, had to use the bucket and stabilizers to lift the tires off the ground and get some brush under the tires! 2E14FA7C-E349-4BE4-80EC-7F8A857E1F21.jpeg 34B4612B-93CC-4E4D-86AE-80C6030B8238.jpeg F8AF9342-2687-4A39-A412-6DBFEDF38A5F.jpeg 0E7AF9B8-A42F-4F82-9CA1-918253724C6E.jpeg
FreezinGator
BX1500 LA181 FEL 48MMM Back blade
Jul 10, 2020
58
Upstate NY
Had to change the fuel filters on the BX this morning. I have been working on the wood pile for next year and yesterday it started to lose and regain rpms intermittently as it was getting dark. The filter by the fuel pump was pretty dirty. The filters had about 80 hours on them. I keep a couple on hand all the time in case this happens or they freeze up. It is running great now. I think I am going to pick up a spare fuel lift pump when I replace the filters just in case.
je1279
Dec 6, 2020
832
585
Upstate NY
Did some dethatching with my chain harrow in hopes of growing a halfway decent lawn at some point.
6,883
Found a power pole (or telephone pole) in the river and used the 180° BH swing to pull it onto the trail, it'll make a nice flagpole! Then got the tractor stuck :confused:, should have known better, pretty soft ground. Good learning experience, had to use the bucket and stabilizers to lift the tires off the ground and get some brush under the tires! View attachment 57972 View attachment 57973
Awesome. It would seem appear that one can still get stuck with R-14's.
I do have just one suggestion for the next time it happens (and it will :)). Next time, forget the brush, just use the hoe to push or pull you out of the jam. You won't even get your boots muddy. ;)
Anyway, congrats on your new machine.
River19
Sep 10, 2020
351
665
NH/VT NEK
River19, I thought I recognized that Ash tree from the Forestry Forum. ;)
Yup. It was too unpredictable for me to try on my own. My will to survive is larger than my ego......had a local young guy deal with it.....he usually specializes in tactical tree removal and is a climber......he climbed the adjacent tree that it was hung up on and took the limb off to allow it to fall more predictably. Then dropped another wounded maple that was in the way and then the ash, which was a fighter.....
I was fine with the cleanup afterwards as I want the wood, but glad I had him out and he made some coin which helps a local guy pay his bills.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I am glad that you used your wisdom and got it down the easy way.....by someone else. (y)
Now you can help me with this one that partially fell last night. LINK
River19
Sep 10, 2020
351
665
NH/VT NEK
I just saw that......heck of a leaner. That will be an interesting one. Then again, how many a really "text book"....they all offer some level of challenge and danger.
nbryan
Jan 3, 2019
1,414
933
Hadashville, Manitoba, Canada
Cleaning up around the yard and driveway area with the forks and loader on today, then switching to the front snowblower in prep for tonight's through Tuesday night's snow storm coming. 10-12 inches wet snow expected! Need the moisture badly here so quite happy about it actually. Clipboard01.jpg
bx tractorjoe
Jun 3, 2020
258
141
loxahatchee flordia
Doing a full service on the new to me bx2200 at 562 hours.
New oil and filter, both fuel filters, air filter, hydraulic oil filter too..
Spent about 300 at messicks, bought Tuesday night and the parts were delivered to South Florida this afternoon
Got new anti scalp wheels for the 54 inch mower, new mower belt, new blades, few spare spindle bearings and one of the anti scalp arms as it was bent.. will be ordering new anti scalp wheel bolts as a few have groves in them tonight..
Also got a new alternator belt..
Going to grease everything underneath and try to adjust the trettle peddle as it likes to creep forward and does not always return or is slow to..
Did the oi change today the rest will have to wait till tomorrow..
Will be useing the l2501 to do the mower deck work.
Well it's leaking.. was mowing and smelled gear oil.. going to pull it apart tomorrow and see what's bad.. hopefully just the seal and no gear case issues.. that stuff is $$$
foobert
BX2380
Mar 25, 2021
110
105
Washington
Picked up a 2 axis rear blade off craigslist for $300. 60” should be about right for my needs. 66F4AFD6-7771-49C5-B32E-4F6D46EE9165.jpeg D1FF0357-F127-4EA8-9CC8-2556F82B2D04.jpeg
random
Nov 2, 2020
716
401
NC
Good looking jobs by you both Ken and random!
What setting hole for your shoes did you have your tiller set at random?
I was thinking one could set them for the deepest setting and use the 3-point to adjust the depth. Although it's prolly easier to just drop and go.
Lowest setting on the tiller, and just let it go as deep as it wanted. Kept it REALLY slow.
forky
Feb 23, 2021
344
385
Wisconsin
Thanks for the information random. It's been raining here for days and more to come as well as chilly temps....so it will be a while until I can fire mine up. I'm so looking forward to playing with the new equipment. My heavy soil needs a good tilling for sure.
random
Nov 2, 2020
716
401
NC
I have REALLY nice loamy soil, so it wasn't too hard to till. If yours is really heavy you might want to try a first pass at half depth first. Of course, no way to tell for sure until you try.
Weasel1
Kubota L2501DT, Land Pride Rotary cutter, Kubota bucket
Jun 28, 2020
35
35
East Tennessee
Cut our new pasture land down for the first time. Next week fencing and equine watering system.
pokey1416
Jun 24, 2020
572
884
SW Michigan
Met up with some friends to raze an old barn and salvage what we can. The LA805 barely clears sides of 40CY dumpster. I actually liked using the forks to feed scrap fire pile, just flip it in (y)
