My fuel pump isn't getting any power. Followed the checks from WSM, pump is working, no voltage coming through the connector when tractor is turned on.
I've checked all the fuses twice for continuity, everything seems to be fine. WSM says "check the circuit". I'm trying to follow the diagram but not totally sure where, physically, to find everything. From the diagram it appears related items are Engine Relay and "J/C 1", which leads to a a couple connections to the ECU.
I'm really hoping it's not the ECU but I'm not feeling too good about it right now.
Other than simply physically tracing the wires (under the body panels etc), any tips or suggestions? Hoping maybe someone's run into this before...
