What type of grapple for my B2601? Tightly closed or more open?
davidmem
Soon to be owner of Kubota B2601 Toro TimeCutter Model 7577
Mar 14, 2021
179
78
Bethany, CT
Newbie looking for advice regarding what type of grapple to get . I looked at the land pride and noticed that style does not have much of a gap when closed between the lid and the bottom . I've also looked at this MTL that has a larger opening when the lid is down .
So I'm wondering if this is the major difference between these two styles, one maybe better for pinching things like brush in the lake and the other with the opening better for grabbing things that are larger. I do not have brush on my 1.6 acres, and will be using the grapple to help me lift things with my aging back . I do heat with firewood and split my own wood so this would be helpful moving large stumps and potentially logs . I'm concerned about the inability to clampdown though with the more open design . Any other considerations or advice with respect to my choice . I have looked at the EA weighed grapple that people seem to really like here . That design also clamps down more narrowly .
Very much appreciate people's advice and guidance here.
PaulR
Aug 3, 2020
579
459
Hadley, MA
BX 23S owner
I went with the Landpride SGC 0554 for a couple (probably stupid) reasons.
1) Weight: I looked at a few others and they were 300-500 lbs or some such crazy weight. I thought that's nice its heavy duty but I'm losing half my carrying capacity with just the unit itself.
2) My dealer had it in stock right there, and I was going to have him also install the 3rd function, so it made for a nice quick package deal.
I have literally 10 minutes of operating time with it as it is brand new to me, so I can't really tell you if I like it or not yet. I took it back off to run my sweeper all weekend.
GSD-Keegan
B2601 with Fel and Bh70 backhoe
Mar 6, 2021
611
808
Ontario, Canada
Newbie too who will watch this thread. Grapple on my list too. Lots of videos out there to research.
Another brand is Artillian for you to check out. They are a little different with removable modules.
je1279
Dec 6, 2020
728
469
Upstate NY
Weight is definitely something to keep an eye on. I'd stay under 300lbs with whatever you go with. Also, I prefer the type with the curved lower jaw as it can be used to remove brush also. I have an EA Wicked 55 on order but know there was a 3 month lead time when I ordered it. If the dealer has a 54" Land Pride unit available that's priced similarly you may want to go that route to avoid the wait.
davidmem
Mar 14, 2021
179
78
Bethany, CT
BX 23S owner
Do you not like the land pride a unit?
Bmyers
May 27, 2019
3,293
3,849
Southern Illinois
I have the EA 55" Wicked Root Grapple. Depending on what your needs are determines which grapple will work the best for you. The clamshell design has worked well for me. Realizing that any of these grapples work better than no grapple.
davidmem
Mar 14, 2021
179
78
Bethany, CT
Thank you. I'm just very curious if the main difference is in weight and then the amount of open closure when the lid is down. Not sure which functionality would be best for me, a more narrowly closed grapple when the lid is down or one that is more open when the lid is down.
The MTL unit pictured above does have a good pinching action too for pulling out fence posts and small shrubs and stuff.
Really wondering about the advantages disadvantage of the amount of closure.
Bmyers
May 27, 2019
3,293
3,849
Southern Illinois
My two cents, the weight is a bigger issuer than the closure. If you use up a majority of your lifting capacity with the weight of the grapple, it could limit you on some the projects you might want to tackle.
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
339
277
Bigfork Minnesota
I went with the 55” EA Wicked grapple as the weight is only about 230 pounds. I also looked at the Land Pride that the dealer had which would have worked as well, but felt the EA was better built. This was just over a year ago so there were EA’s in stock. I only had to wait for shipping time to get it. It has done everything I have asked of it, but it a struggle to pick up multiple rounds of firewood with the single clamshell design. My main reasons for the grapple were brush, and lifting logs and setting them on my sawmill. Which it does both really well.
If I had to do over, with all of the things that are happening with out of stocks and extended lead times, if there was a Land Pride sitting at the dealer that I could get today, I would probably get the Land Pride. I think the EA is a better grapple, but I absolutely hate waiting for stuff. If you can wait, get the EA 55” wicked grapple and don’t look back.
davidmem
Mar 14, 2021
179
78
Bethany, CT
I'm waiting on an ETA for my tractor, B2601. First estimate was May 21st but the dealer is going to try to firm up. Waiting is really not an issue. Only way I can get an EA is if the shipping terminal can put it in my friend's full size pickup truck.
Bmyers
May 27, 2019
3,293
3,849
Southern Illinois
I sent my dad over with his F150 to the terminal, they placed it in the back of his truck and we unloaded it with a couple of chains once he got to the farm.
It is actually light enough a couple strong individuals could unload it (taking it off the pallet of course),
DeepWoods
Apr 10, 2019
339
277
Bigfork Minnesota
When I picked mine up, we slid it off the dock into my 5x8 utility trailer with no problem. It comes shipped on a pallet that will fit between the wheel wells of a pickup box. The worst thing about picking mine up was it was minus 35 degrees out and I had to be at the freight terminal before 7am. So I had to drive two hours in the dark to be there on time. STILL WORTH IT!!!
