another tie rod end
chris989
L3450
Oct 5, 2016
35
boise
Hello all,
I am in the same boat as others and search some older threads.
Kubota wants ~$400 per side for my tie rod assembly. Both the inner and outer are toast on both sides so this is almost a grand to replace.
I have been searching catalogs for the inners 35080-4460. I can fab just about anything for the outers.
Does anyone know of a source for the straight 18mm inner joint or a link/idea how to safely fabricate something.
My 3450 is no cream puff so a little frankinfab wont hurt it.
thanks,
Chris
2,839
3,527
How many hours on your tractor?
What are all you guys that lose tie-rod-ends doing with your tractors that are killing the tie-rod-ends?
Are Kubota tie-rod-ends made of unobtanium which is very soft and untempered to cause so many failures?
Tie-rod-ends should be very durable.... the ones on cars/trucks last for 100k miles and a decade or more.
What’s with these...?
6,716
Not sure Geo. but they even have a shield to protect them. Folks have to be driving through deep thick brush piles!
5,729
maybe a lot of heavy loader,turning the wheels wear ??
With power steering it's easy to not 'feel' the stress turning the wheels without moving,something 'armstrong' sterring lets you KNOW .
as for replacements, I'd be searching the net for anything that 'fits the holes'....
orange crusher
BX 2680
Sep 30, 2017
354
482
ontario canada
Hey, you can work a D-4 Cat dozer just like a D-8...................................................for a while.
Works on the same principle as putting bigger springs on the rear of a 1/2 ton truck and make it a 3/4 ton.
bjmsam
L3710 HST
Feb 19, 2010
30
12
Mount Airy, MD
On my L3710, all four boots had deteriorated and all four ball joints were dry with considerable play. New tie rod assemblies are super expensive (HTA0A-13700 ASSY ROD TIE RH is $491.52 for OEM at Messick's or $290.40 for aftermarket at Worthington, and TA040-13700 ASSY ROD TIE LH is $375.20 for OEM at Messick's or $172.81 for aftermarket at Worthington), so I figured it was worth attempting repair before replacement.
I bought 32580-44770 COMP.END TIE ROD RH (aftermarket on Amazon for $31.59 with zerk grease fitting) and a set of four 32580-44780 COVER DUST (aftermarket on Amazon for $35, with one unused as a spare). I removed the old, contaminated grease from the ball joints with solvent before packing in fresh grease and reassembling. It worked out better than I expected, as all four now are nice and firm!
NorthwoodsLife
Oct 15, 2021
1,327
1,331
Wisconsin
Probably out sourced to China or Thailand, Cambodia, etc.
This should NOT be an issue. Even with a full bucket in mud or otherwise.
I have beat the living sh1t out of Kubotas in the past. Never had a steering issue.
