B2601 grill tilt guard
Cdnmaplesmoke
B2601, 10+ implements
Feb 25, 2021
Ontario
Does anyone have a new b 2601 ? I just bought mine a month ago. My foam covered release handle for the grill guard tilt mechanism nearly touches my exhaust and the foam is burning off and getting blown all over my loader. Just wondering if anyone has the same issue or photos of the way their grill guard tilt mechanism lever is installed. Sent pictures to dealership but have yet to hear anything. Thanks in advance
B737
LX3310
Jun 9, 2019
2,024
2,200
wow, my 2601 does not have this 'feature' it was delivered in Oct 2020. Can you show a few more pictures of this mechanism? which loader do you have, as the grill guard comes with the loader.
welcome to the forum btw!
2,921
1,383
I was thinking the lever should be pointed forward, but I am not sure.
B737
LX3310
Jun 9, 2019
2,024
2,200
Nice find on the installation instructions! I cannot find this kit on parts website...
Closest I came was finding it in a march 2020 whole goods price sheet under "FRONT QH DRIVELINE/COMPLETION KITS" for $58.00
update: was able to order it through whole goods at Messicks, it is on back order until April/May like everything else in the world
Cdnmaplesmoke
Feb 25, 2021
Ontario
B737
LX3310
Jun 9, 2019
2,024
2,200
so much better with it tilted back. Most of our 2601s stick obtusely out.
I wonder if the handle could be switched to the other side by flipping the kit.
Cdnmaplesmoke
Feb 25, 2021
Ontario
Yes it’s nicer tilted back. You just have to tilt it forward to open the hood. The hood latch is on the opposite side I don’t think you can switch it ...
B737
LX3310
Jun 9, 2019
2,024
2,200
ah forgot about that, yes that makes sense.
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
333
97
Ottawa, ontario
Talked to my local dealer and he has them in stock. $99.00 cnd but its only the pivot parts , does not come with a new grill.
B737
LX3310
Jun 9, 2019
2,024
2,200
well Messicks said this tilt kit would be available in May or April. However, they called yesterday to say that it's being fedex now. Will report back on the retrofit
ayak
L3301 HST
Feb 16, 2018
609
820
WV
For what it’s worth, on my L-series, the hood latch as well as this foam-covered pin (mine isn’t foam-covered) are on the same side, opposite of the muffler. Was like this from the factory.
B737
LX3310
Jun 9, 2019
2,024
2,200
Sorry im not much help to the OP but i got this kit installed today. I can't believe these things don't come delivered this way.
Only tricky part was compressing the spring to insert the cotter pin. I used a 12mm box wrench and a wood clamp. Everything fit right up.
Before 😲
After 😁
box wrench and wood clamp to compress spring to insert pin.
B737
LX3310
Jun 9, 2019
2,024
2,200
last thing... to @Cdnmaplesmoke, it appears your handle my not be set right. I believe it should be pointing straight forward, yours appears to be down.
awesome
B2601, BH70, K54-22-06B
Sep 16, 2018
262
175
ottawa
I just got a b2601 last week. I can confirm that the handle should not touch the pipe. Mine doesn't.
Fyi: be careful if you lift up your 3ph when the rops is folded down. I bent my top-link on day 1 because of that 😖
