Brand new member, but long time Kubota owner. After a search yielded this thread, I had to join to get some info. Ive been having a recurring issue with my BX2750 snow blower set up for some time. The first time it happened near scared the crap out of me! During a routine snow storm in 2014, I was blowing about 6 of typical New England snow when I started to hear a foreign noise coming front below near the front section of the mid PTO shaft, and in an instant all **** broke loose...well not quite literally, but the forward end of the mid PTO shaft separated from the rear male section that is integral to the quick hitch. I luckily disengage the mid PTO before the uncontrolled spinning shaft caused any damage to the tractor. After bringing it in the garage and inspected the damage, the front universal joint of the mid PTO shaft appeared to fall apart. Ok, no problem!
The spare universal joint was shipped by Messicks within a few days. I pressed the new joint in successfully and installed the mid PTO shaft back on the tractor. Started it up and ran the mid PTO with no apparent issue...problem fixed!
Next snowstorm I was all too happy to get out there to clear the drive, when all of a sudden...yup, same thing occurred. So I guess I didnt really fix the problem, and only merely repaired the mid PTO shaft. Luckily I had purchased an additional differential joint, as the issue resulted in the same front differential blowing apart. So something else had to be causing this failure.
I repaired the mid PTO shaft with the spare differential, and did a much closer inspection to the entire mid PTO driveline. I determined it was not the differential failing. What I found was that the shaft that runs through the quick hitch hitch was loose and could move forward and aft through both pillow block bearings. Seems as all (4) set screws that are suppose to hold that shaft in place were loose. Thus, the amount of spline engaged into its mate kept getting less and less until it was not enough and spun right out. I will note that during initial install a year prior, those set screws were torqued to spec and I used blue loctite. So I reset the shaft, reset the set screws, re-applied blue loctite, and re-torqued and also lubricated all fittings again. I ran the blower for 15 minutes or so in the garage, shut it down and re-inspected all joints and connections to be SAT. Been using the machine and BX2750 with no issues.
Fast forward to this season...installed and inspected all components that make up the BX2750 to my BX1500. The third time clearing the driveway this winter and not even 50 feet into my fist pass and guess what? Aside from the resulting mid PTO shaft and differential blowing apart, the quick hitch pillow block set screws came lose.
I went through the same drill again to reset, re-apply, re-torque.... I placed yet another order to Messicks for a few more differential spares, as well as a new mid PTO shaft (the original has gotten pretty beat up when it’s flapping around uncontrollably during the failure mode).
So asking if anyone might have had a similar issue, and if you truly resolved the issue. Perhaps I need to go through the process loctite and re-torquing every season? Tap bigger set screws? Replace the pillow blocks? Im open to any and all comments and suggestions. Thanks in advance for your help!
