Wheel spacers (BX2380)
Nodlenor
BX2380 w/loader, tiller, blade, dirt scoup, & Woods 5' 3 pt. mower.
Nov 22, 2020
45
11
North central Missouri
Just wondering how many have put wheel spacers on on their BX's. What are the advantages? Will it void the warranty? Any other information I need to know if I decide to purchase them (or whether I should).
2,871
I'll tell you this - made more of a difference than you can imagine ............
Until you drive a BX without spacers ............. then place on - and go along that same old hillside - you will literarily feel it in the seat of your pants.
Kubota OFFERS spacers ..... so NO will not void warranty.
IF MMM installed - be careful of width of spacer.
I have 2" on mine - and really good money spent
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
373
161
Southern Worcester County, MA
I myself have had a hard time trying to figure out what width I should get. I have an 1880 with a 54" MMM. But can't seem to find specific with I need. I definitely want to do them though!
2,871
be careful with the width WITH the MMM - the outer wheels will hit the tires if pushed out too far.
Mrlunchbox
Nov 21, 2020
373
161
Exactly! I just don't know how to find out what size works lol. I've heard you cant go out max width because of the mower. Too bad actually as I've seen 2" spacers and the overall stance is awesome. Looks wicked stable.
Nodlenor
Nov 22, 2020
45
11
I don’t have a mower but I do have a loader, I also till several gardens. My tiller is 48 inches wide so I don’t want to go too wide. A little stabilizing wouldn’t hurt though. I’ll have to do some measuring and see what I can do. Thanks for the info.
3,257
My son in law's BX23S we put on 2 inch spacers because he does not have a MMM. My BX2200 with the MMM, I could only use 1.25 inch spacers
Both were cheap and well made off ebay, or amazon, or walmart.
Made for a jeep but work on the BXs perfectly.
There are threads here and at TBN on this subject with specifics if you search and are interested.
2,871
I think with a 60" MMM - 2" is max ......
with the 54" - the 1.25 are the max
2" on the BX25D is almost 48" wide once installed - so the bucket is 48 and the rears are almost the same.
5,811
I'll never use a MMM on my BX23S, but have moved mountains of compost/fill/oil with it.20-30 tandem loads every Spring. I've never needed wheel spacers, however you do need 'ballast' out back, so I leve the BH on.
As for tillering, there's never been a 'stability' issue.Used to do about 5 ac 2-3 times a years. Can't see how as the soil is already a 'garden'....so reasonably flat and level ? Got me curious as to what 'stability issue' you're experiencing ??
Nodlenor
Nov 22, 2020
45
11
Greensvillejay; You would be surprised at some of the places people put their gardens but mostly I was concerned about the width. I don't want my tires to be wider than my tiller. As for the stability issue, that is when I'm using my loader. Not all places are as level as I would like so more stability would help.
BXHoosier
BX24
Jan 21, 2018
497
591
Indiana
I have 1-1/2” spacers on my BX24. I added them to give me clearance for tire chains. With 1-1/2” spacers, the loader bucket is still wider than the rear tires.
Nodlenor
Nov 22, 2020
45
11
I measured my tractor rear wheels 45”. My loader bucket measured 46 1/2” and my tiller 48”. So I guess I would be ok with the 1 1/2” spacers. That would make my rear tires 1 1/2” wider than my bucket which wouldn’t be too bad and even with my tiller so that should work also. Three inches doesn’t sound like much but may make more difference than it sounds like it would. I wanted a little wider tiller when I bought mine but couldn’t find anything under 60” which I thought was too much for my tractor.
