fuel pump
5,553
OK , well I guess I am officially old! I went to hoist a fuel can up to fill the wee beasty and found out I aint 21 no more. So with that in mind, what kinds of pumps, hand crank, or electric is anyone using. Yep I did have a barrel set on its side raised up and used gravity but I found I cant the the cans up that high any more either,,, Sucks getting old ,,,, Here is what I was thinking. like maybe a HF dolly with a piece of ply screwed on it and maybe a strap to hold a small plastic barrel so it dont move or fall off, and a hand crank pump (a cheep one). BUT hey I am open to all ideas.
johnjk
Apr 13, 2017
1,796
2,185
West Mansfield, OH
I bought this last year ARKSEN 30 Gallon Portable... https://www.amazon.com/dp/B07VP5MZQ8?ref=ppx_pop_mob_ap_share. It has a hand crank so to fill it from your transfer jugs you just turn the handle the other way to suck fuel out of the jugs. I don’t have forks so a smaller unit I can place in my truck was out of the question.
3,058
My wife bought me this one for xmas.....
Pump
have not used yet! No grass to cut nor boat to run:ROFLMAO:
bmblank
Mar 4, 2015
774
496
Cadillac, MI
Damnit Skeets, I've been thinking the same thing.
Hokie, I've been looking at that thing. I think the thing that turns me off the most is the speed. IIRC, it's something like 2gpm... It would take 5 minutes just to fill the dang tank... That's pretty darn slow. And I don't think I could trust the automatic shut-off.
Let us know how it works.
pokey1416
Jun 24, 2020
572
885
SW Michigan
Got these. Not cheap but after wife had to help me a couple times ;) she asked me if there was a better way to fuel up.
old and tired
1,919
1,297
My (cheapskate) plan is to just use 2.5 gallon jugs when I can not lift up the 5 gallon ones...
7,323
skeets - I can relate.
I don't have an issue with the Kubota BX and diesel, but have problems with the old 'Moline and gasoline.....
I think the MM has a 15-20 gallon tank. I can easily heft 5 gallons up onto the top, but it's a bear to pour..... that wasn't an issue at age 25 and filling up before a day of firewood....
Are these battery pumps that you guys post safe/usable for gasoline?
3,850
2,391
Here's a po boy's method. Rig an extended hose on the fuel jug with a clamp on the end. Put the jug, tilted over, in your loader bucket and raise it higher than your tank. Put the hose in the tank and remove the clamp.
Note: I've never done this but it's not an original idea. Of course if you've run the tank dry this won't help.
je1279
Dec 6, 2020
834
585
Upstate NY
Gravity suction is definitely another option. Just takes significantly longer.
torch
Jun 10, 2016
2,880
1,126
Muskoka, Ont.
Pump
I have been using one of these for a couple of years now. In fact, I liked the first one so much, I bought another. So now I have one for the gas cans and one for the diesel cans.
Comes complete with an automatic shut off that kills the pump when the fuel level gets to the nozzle tip. No more spilling starting and no more overflowing at the end.
7,650
Skeets here's something you might be able to fab up and make pumping fuel easier. I made one out of steel, but you can make one with wood and screw/glue it together. It's simply an upside down "U" that set over your loader arm. There is a flat board on top to set the fuel can on and stays there without support. Then you can use a siphon pump or any inexpensive pump to easily fill the tank.
You could use 2x4 or 2x6 on the sides, 1/2" plywood on the top. I made the U wide enough to allow a piece of inner tube to set on the loader arm to prevent scratching. Just a thought.
3,535
Me too. Here is an older thread discussing smaller cans. And I love the 2.5 gal Orange can.:)
5,553
Thanks guys, lots of good ideas, and the one for the bucket that is thinking outside the box thanks. I would like to see how it works D2, a couple pics would be cool ;)
bearbait
Dec 9, 2011
4,223
979
New Glasgow Canada
Sorry skeets just noticed your thread, cheap and easy would be a boat bilge pump. I wasn't sure they'd be good for fuel but when I did a google search it turns out it would be fine. The link I'm posting is a Canadian site so probably half the price for you EH.
