Block Heater
Stmar
B2650HSDC
May 23, 2017
946
57
Buffalo, Wyoming
B2650 with dealer installed block heater. Can you leave the block heater plugged in during cold weather? My remote went out, coldest week of the year of course, and I won't be able to replace it this week. Got it started yesterday, hard start even though it was parked in unheated barn, negative temps all day.
3,028
When you say plugged in .......... you mean like for hours or days?
When you say remote...... like a RF outlet remote - push a button and the receptacle turns on?
To answer you question - it would be best to have at least an HOUR of preheat - more than that will not hurt anything, but will reduce the elements life span. Heard a lot of stories that those heater are not lasting more than a couple of seasons.
You could get a mechanical timer too - you plug it in the night before you want to use, it kicks on for an hour or so and then kicks off - ready for the next day!
I would buy another remote and one of those WATT-O-METERS ...... if the element goes, it will show zero amp draw..... and those meters are nice to have to check amp and voltages too.
je1279
Dec 6, 2020
828
585
Upstate NY
I've always been told not to leave it plugged in for more than 2 hours at a time.
Stmar
B2650HSDC
May 23, 2017
946
57
Buffalo, Wyoming
Thanks, remote was good but line of sight may be compromised also so a mechanical timer may be an option. A guy told me he kept his plugged in all winter but that just did not sound right to me, even if you don't care about your electric bill.
Stmar
B2650HSDC
May 23, 2017
946
57
Buffalo, Wyoming
"When you say plugged in .......... you mean like for hours or days?
When you say remote...... like a RF outlet remote - push a button and the receptacle turns on?"
Days and yes on the RF.
Fastball
L2900, rear blade, finish mower, 200l sprayer, landscape rake
Feb 9, 2017
86
29
North Okanagan, British Columbia
I have mine on a timer for the coldest week of the year (now). Turns on at 8am, and stays on for 2-3 hours. Chances are if I need to use it, it’ll be in the morning.
5,255
1,055
The question of running the block heater is just a simple physics one.
The block heater cannot heat the engine to operating temperature as the heat loss from the block will equal the heat input from the heater. The colder it is outside, the lower the block temperature will be when heat input equals heat loss.
The heater does not mind running continuously, it is the on and off cycles which eventually end its life after many years. The heater is not equipped with an over temperature safety switch or a thermostat so when turned on it stays on. The on and off cycles I refer to are just the daily use ones.
Most block heaters are in the 400 watt range. If your cost for electricity is 20 cents per KWH your block heater is costing you 8 cents for each hour of operation.
The thought that don't leave it plugged in for more than 2 hours is because after about two hours the engine has warmed up as much as it can and longer use just wastes energy. It has nothing to do with the heater longevity.
nbryan
Jan 3, 2019
1,400
928
Hadashville, Manitoba, Canada
I can't understand there reasoning behind having to unplug a block heater from your tractor after 2 hours. Unless the frost-plug style block heaters are so powerful that they'll overheat the coolant? I doubt it! Any clue why you've always been told that? Mine is often plugged in overnight and longer! If there's something wrong with that, I'd like to know! Other than a bit of an electricity waste.
3,028
Again - nothing wrong with it...... if it is the best alternative - then go for it!!! If the shed is 100 yards away - and getting dressed and tipping out there at 5 am to plug it in to use at 7 am ...... I would say the hell with that too!!!! I would plug it in at night at let her rip!!!!
But a simple analog timer can fix all of the above easily!!! The only problem you have left is to REMIND yourself to plug it in and UNPLUG it before leaving the shed!!!!
https://www.amazon.com/dp/B00MVEMD7...fwT2&ref_=sbx_be_s_sparkle_lsi2d_asin_0_title
I had a battery maintainer that I left plugged in ......as the boat came out of the slip ..... stupid is as stupid does! :oops:
10,678
Block heaters have thermostats in them, so they heat up to a temp and then self shut off.
Every installed block heater has a different life span due to the way the element can heat the coolant / water, and many other factors.
Kubota engines are hard on heating elements because the tend not to get enough coolant / water around the element so heat dissipation and boiling occurs, when they boil off they tend to cause the element to spike in heat because the thermostat in the case of the block heater doesn't read the heat being too high.
A good setup can run 24/7 without issue but it's like anything, the more you run it the less time it will last.
And yes they can eat quite a bit of juice especially when outside temps reach -19 like it says you'll get.
My main question is are you going to use the tractor when it's that cold out?
I don't see any snow in your forecast, so a better bet is let it chill down and take a nap till this cold streak pops on past.
nbryan
Jan 3, 2019
1,400
928
I was actually more interested in why je1279 was advised against leaving his tractor block heater plugged in.
I actually do have a mechanical timer for block heaters, just haven't needed it lately as I'm not trying to leave early for work anymore I just plug in a few hours ahead of when it's needed here.
je1279
Dec 6, 2020
828
585
Upstate NY
I did some research based on the responses above and what Dave_eng said seems to be the most likely reason. Beyond two hours, the tractor will not get any warmer and you are just paying to maintain that temperature. I guess it's up to the owner on whether to only plug it in a couple hours before you plan to use it or keep it plugged in so it's ready whenever.
5,255
1,055
My experience is with outdoor permanent emergency generators. You never know when they are going to be required to start and they have to go to full rpm's in a few seconds so no warm up. In the days before synthetic 0w oils the heater stayed on year round.
Now a device like a thermo cube turns the heater on a lower outdoor temps. cost less than $30
Thermocube
nbryan
Jan 3, 2019
1,400
928
I'm guessing you mean that they eat quite a bit of juice because the block heater will be needed to be plugged in for longer because of the lower temps? Not because they draw more current the lower the temperature.
And I was out blowing snow yesterday in -15F and strong winds. Took a while to warm the machine, obviously, but it ran great otherwise.
3,028
Thermocube
Used them when I had chickens - kept the water from freezing - work great!!!!
3,373
Where does the Barn get its power from?
Mine is fed from the house, so I plug the heater in and trip the feed breaker, and re-close the breaker when I want to heat the engine.
Might not work for you though.
Stmar
B2650HSDC
May 23, 2017
946
57
Buffalo, Wyoming
Above zero today so had a chance to go through the system, a little cr2032 battery in the handheld transmitter. So the issue was in my hand the whole time. The light came on but the signal must have been weak, wouldn't even turn it on when next to it. Changed battery, presto, good as new.
Learned a lot from this thread though.
Stmar
B2650HSDC
May 23, 2017
946
57
Buffalo, Wyoming
No, too many things on that circuit.
Stmar
B2650HSDC
May 23, 2017
946
57
Buffalo, Wyoming
I think the thermocube turns on at 35 deg. If so, the heater would be on for a long time!
Looks like there are different models, TC-1 turns on at 0 and off at 10 so that would be good for tractors. Only time mine is hard to start is below zero.
