Swift-tach hydraulic quick connector keeps disconnecting
Henrik
BX2380
Nov 6, 2020
Alberta
I have a BX2380 with only 60 hours. The quick connector for the hydraulics for the FEL has been disconnecting more often to the point where it's happening about every 10 minutes when I'm using the loader. I'll hear a click as the handle pops up and the loader stops working. Anyone have any solutions or do I need to take it to the dealer which is a two hour drive away?
orange crusher
BX 2680
Sep 30, 2017
354
482
ontario canada
Yeah.............get rid of that piece of crap manifold system and replace with 4 pioneer couplers. That system is a joke.
Crash277
BX23S
Jan 17, 2021
844
621
does yours not have a lock pin for the handle? Ive only used it on my 2020 BX23S and there is a locking pin. I have 90ish hrs and have had my loader off about 8-9x at least with no issues
Henrik
BX2380
Nov 6, 2020
Alberta
Yes, it does have a locking pin; that little red knob. It locks when I connect it but doesn't stay that way any more.
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
Given that you live in Alberta and it is winter for a while longer, try calling your dealer. It is under warranty, and they might ship you some parts you could change out yourself.
orange crusher
BX 2680
Sep 30, 2017
354
482
ontario canada
I've been lucky I guess, mine has never leaked or given me any trouble whatsoever. Hope it stays that way.
Dealer did 2 recall warranty repairs (new manifold each time) and neither lasted more than 6 months. Since I modified mine it hasn't leaked yet in 2+ years, and when and if it does it is a 2 dollar fix I can do myself. Simple solution for some idiot college boy engineer's cheap design.
B737
LX3310
Jun 9, 2019
2,022
2,204
I can appreciate the ease of the new flat face manifold system, mine hasnt started leaking, yet. It certainly does simply things. But is it really that hard to pull off 4 individual connectors? You have to get off the tractor to disconnect the 3rd function hoses anyway. Seems like the whole thing was a solution in search of a problem.
I like the new design, but can see me going @orange crusher route down the road...
@Henrik something has got to be up with the spring-loaded locking pin
802Driver
LX2610SU 60" Bucket Land Pride54" Box Blade Farm King 4572 Rear Blade
May 18, 2020
122
91
Manitoba, Canada
Locking pin could be slightly bent, in the meantime, I would wait til it warms up a bit, use some heavy duty zip ties to secure it.
Crash277
BX23S
Jan 17, 2021
844
621
There is something I didn’t think about. I’m getting the 3rd function parts installed. they are installing the manifold between the loader arm and the frame on the left side. In my new guy thread I posted the pics of it installed on the rops, I’m having them move it.
Henrik
BX2380
Nov 6, 2020
Alberta
The zip ties are working as a temporary fix. Thanks. I'm leaning toward @orange crusher 's suggestion of individual couplers. The manifold doesn't save a bit of time (or frustration) when you have to reconnect it every 10 minutes.
802Driver
May 18, 2020
122
91
Manitoba, Canada
I think going to individual connections is a good idea, I had the swift-tach connector on the BX I had previous, I had good luck with it but I knew of the cases that weren't so lucky. So when I moved up to the LX I have now, I opted for the standard FEL with individual connections. I don't find it any less convenient than the manifold hook-up on the swift-tach.
