finally got a brand new b2650 tractor! The other day before i used it i went out and checked the oil level and it is well over the second hole on the dipstick!
manual says it should be in the middle of the two holes on the dip stick.
Is this anything to worry about? I've only put 6 hours on it. Should i drain it and put the oil back in to the propper level?
Oil looks brand new as it should and yes i'm on level ground and the tractor has been sitting for days.
I also noticed the dealer did not put anything on the battery terminals what is best to put on them to stop corrosion? On my cars i use a spray. Is there anything i can put on the hydraulic connections to stop rust? One has already started to rust.
