Anybody know a source for these bottles?
2,550
Looking to buy some of these bottles- down to my last one, and they are perfect for brushing on oil for tapping, drilling, turning. etc.
They are impossible to tip over, but somewhat fragile when you knock them off the bench onto the concrete floor. :rolleyes:
Ideas?
Nicfin36
Jun 19, 2019
1,016
466
Decatur, AL
I looked a bit online, probably like you did, and did not find anything resembling your bottle, at least not in glass. I did see plastic ones without a screw cap. However, in the back of my mind, it seems I have seen bottles like that at one time. I want to say, I saw those type of bottle used in hobby paint. That was probably a long time ago.
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
Look in a lab supply catalogue like Fisher, they should have flasks with and without screw tops.
PapaJ
BX2680 - PFL1242 - RCK54 MMM - Fimco 3PH Sprayer - Trailer Mover
Apr 28, 2020
282
106
VA
I don't know a source, but I think it's called a conical flask or an Erlenmeyer flask
Nicfin36
Jun 19, 2019
1,016
466
Decatur, AL
Yeah, looks like your best bet are the Erlenmeyer flasks with screw caps. I see they have 50 ml ones on eBay.
2,550
As long as you can see the contents through the side. I found a steel can about the same size & shape, but you could never tell how much was in there, and it always ran out at the most inopportune times.
2,550
Another feature of the bottle I want is that it is tall enough, with a narrow enough mouth, to keep the brush standing up.
I searched for "cone shaped bottle" and found antique ink well bottles on eby, $10-$60 ea.
BigG
Sep 14, 2018
1,951
770
West Central,FL
My wife buys frappucciono by the case. You can by it by the bottle at 7-11. Small glass bottles with lids and a large mouth for "free".
bird dogger
Vendor Member
Feb 24, 2019
1,601
1,459
North Dakota
2,550
These might be close to your needs. Shatter proof plasic, clear on the bottom part, good chemical resistance. Description: 2 Pcs Plastic Conical Flask, Erlenmeyer Flask w/ Cap 50ml, Shatter Resistant
Example: 2 Pcs Plastic Conical Flask, Erlenmeyer Flask w/ Cap 50ml, Shatter Resistant | eBay
In fact, I think I'll order a couple to have sitting on my lathe table. :)
I wonder if they's be heavy enough to be tip resistant- less than 2" base, but 3 1/8" tall....
2,550
Looks like paint storage bottle for an airbrush
I think we may have a winner!
Never thought of an airbrush accessory; my airbrush has smaller, straight side bottles.
My oil bottle is 3oz, 2 3/4" base, 2 7/8" tall, and came with a black bakelite screw top. (got 2 from an estate sale)
These are 3oz, 2 1/2" base, 3" tall.
2,550
Thank You to everyone who took the time to search for this item for me.
Checked around and the Amazone deal that i7win7 posted was the best deal, so they are on order.
This is a great forum!
6,382
I have several of that exact bottle in front of me, yep super hard to tip over.
The are actually 2.5 inches wide and 2.5 inches tall, the 3 inch measurement with the metal top.
Creature Meadow
Sep 19, 2016
1,064
135
Central North Carolina
I have this style but no tops for the small ones.
If you were closer lil Foot I would be happy to drop them off.
2,550
Thanks for the thought, I appreciate that brother!
I'm sure the ones I ordered will do the trick, a tad smaller and lighter, but completely serviceable.
I did check with Fischer Scientific & VWR Scientific (now part of Avantor) and they had similar beakers & flasks, but I remember from my days in the chem lab that they are pretty fragile compared to my oil bottle, which is very thick glass, pretty stout.
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
There were some in my lab with screw tops and heavier glass that might have worked, but when I got into the catalogues they were pretty pricy. A lot of labs use the plastic flasks, but they would not have the weight you need to make them stable.
2,550
Agreed!
