I've got many plans this year for clearing a few areas and also for tidying up many downed trees. In an effort to be more efficient I invested in a small farm dump trailer to fit on the rear drawbar of my tractors. This is a 2 Ton trailer that the manufacturer says is really capable of at least 3 Ton. I ordered it in an 8' x 5' single axle, they are also available in 6' length and / or with 4 wheels. Empty weight is around 700 lbs for my 8' long with single axle. I'll probably remove the tailgate for most of my woodland use and will add wooden side boards so I can load it full of roots or timber, looking forward to a fast empty using the rear hydraulic remotes on my tractor, main use will be on my L3200 and L3901. Most of my loading will be by grapple or by hand when I can get it deep into the woodland areas where I'm working.
Just need to get the weather to cooperate a little so I can get out to start my work.
Unlike the road dump trailers this just has a cylinder and 2 hoses, wheels sit under the dump bed.
Trailer is just about the smallest one made by Berkelmans Welding who manufacture from 2 ton to 20 ton farm dump models.
