Farmer Brian
I have added hydraulic swivel capability to my Landpride RB0560 .
Parts 4 x 9 x 3/8 steel plate Qty 2
1.25 x 3 inch steel rod Qty 1
1.5 bore x 12 inch stroke Prince Wolverine series cylinder
(Swivel eye at both ends)
Steel tube 0.75 id x ?? od x 3 inch lomg Qty 2
Various hydraulic hoses and fittings
Various linch pins
My setup was made so that I could use it in both forward and backward directions. The cylinder end at the scraper end is removed, blade rotated 180 degrees and reattached at other side.
4 x 9 plates are drilled with a 0.75 hole to match the cylinder swivel end holes. The Steel tube is welded on the bottom of the plate to align with the 0.75 hole to provide strength for the linch pin that holds the cylinder end. The location of the hole in the 4 x 9 plates has to align with the pivot point of the blade. The 4 x 9 plate was then welded to the bottom of the plow support.
1.25 x 3 steel rod was machined down to 0.75 for about 2.5 inch to match the
cylinder end swivel eye. A hole was drilled into the end for a small linch pin. This machined rod was welded to the tractor end of the RB0560.
Before actually welding I clamped all the pieces in place to make sure the blade would swivel plus and minus 30 degrees.
Good luck.
