Relative newbie so sorry for the ignorant question. I have a 2950 tractor and purchased a Land Pride 1672 blade last year primarily for snow removal. I typical remove snow going in reverse and at an angle and have offset the blade to one side (driver's right) so I can get it out past the wheel. I leveled the 3-point hitch attachment and then hook up to the blade and raise the blade an inch or so off a level concrete floor and use the turnbuckles to make any minor adjustments. Okay, this works well for one direction but occasionally I like to turn the blade to use the angle on the other side (driver's left) or all the way around and use in a forward motion. When I rotate the blade it then drops down a couple inches and no longer level. To keep from digging into the ground, I would need to adjust the turnbuckles again. There seems to be no play in the three point hitch (i.e., it's solid). What am I doing wrong to get my blade level so I don't need to adjust it when I switch the angle?
