motionclone
I'd prefer steel plate or wood over concrete. Steel works good for welding tables, clamping fixtures etc. Concrete is only good in compression and when it breaks/cracks you are FUBAR. Not much good for hammering or clamping onto. Quick way to dull your drill bits. Concrete spalls if you apply too much heat so welding and torches are out.Anyone here have or have used or been around a shop with a concrete workbench top? Any downsides?
Im considering putting one into my new to me 32x40 shop.
I have space layed out for about 14' long by 36" deep bench.
Im thinking 4" thick. Lumber is real expensive now and im a mason so id build it out of block then pour a 4" top full of rebar and angle iron for a front edge.
Not really planning on putting anything heavy on it just using like a workbench for disassembly/reassembly of parts, mount a vice on one end etc.
Ive never had a steel bench always been wood. Id consider building a steel bench but im thinking it would be more expensive than block and concrete. but maybe not.
I would build the bench supports out of 8" block rebar pinned to the concrete floor and then block cavities filled together with with the top. 1/2" rebar throughout and 4000psi crete. I build fireplaces and chimney foundations this way sometimes.
As far as chipping the edge I was thinking to put a 3x3 piece of angle steel the length of the top front edge and embed into the crete.
Why 5/8 plywood, that's some serious $$$.im in the process of sheathing with 5/8 plywood and building shelving while im at it.
150.00 at Harbor Freight and I welded a 2" Hex repair collar into the base of it.Dayun thats nice shyte! Whats that puppy cost? 2.5K?
EDIT - looking that up ..... really not a bad price - if'n you do a lot of concrete !!
https://www.everythingattachments.com/Tractor-Cement-Mixers-s/10652.htm
This is funny. I just watched a Jesse Muller YouTube video on concrete workbench about an hour ago. Check it out.Anyone here have or have used or been around a shop with a concrete workbench top? Any downsides?
