I was using my Tractor this week for the first time really working it after getting it back from dealer. They put rear remote in that was on back order when I bought tractor.. I haven't used remote yet. I was blowing snow with my rear blower and it seemed to be struggling a little but thought maybe it was a little slushy under snow. I then took a ride to knock down some snow banks around the corner. I put it High and took off down the road. PTO was off for blower and when I stepped all the way down on HST the tractor was again struggling. I let up on pedal and it seemed fine at half pedal until I pushed it all the way down. Engine would loose rpm . It kind of felt like the Hydraulics where loading it down. If I messed with the rear remote with nothing attached it seemed to load it down to a little while driving. I have the hydraulic chute rotator hooked to my front 3rd function to rotate it. When I first tried to rotate it would only go one way and not go back opposite direction. I swapped lines to get it to go back to the direction to the way I needed it. I have used it with the 3rd function for 2 seasons now. Once I started using blower it started to rotate back and forth like normal. The rotate problem was first. before I went for the ride. After I was done I put it back in garage and let it sit for a little bit and then came out to check fluid level figuring maybe it lost a little when they put the rear remote on. The fluid was a just above the high line on dip stick. I pulled air cleaner and it had a little bit of pieces of crap from brush cutting before the dealer trip. I looked quick at fuel filter which looked clean and nothing I could see in it. It is the original and tractor has about 75 hrs. on it. I did all the Hydraulic filters and full fluid change at 50hrs. Tractor ran brush cutter no problem all summer after I did the fluid change. When tractor would load down I didn't notice any smoke from exhaust. So basically thinking something is up with rear remote. Dealer was closed all weekend so haven't called them yet. I am kind of new with tractor Hydraulics. The dealer picked up and dropped tractor off at my cabin while I wasn't there when they installed the rear remote. I am not really familiar with it but looked pretty straight forward how to use it so never questioned them how to use it. I'm I missing something. Sorry for the long post but wanted to give all details. Thanks Rich
