BX1880 Seat replacement
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
373
161
Southern Worcester County, MA
Hi All, new to the forum and have done lots of research and can't seem to find what I am looking for. Do any of you know if the BX1870-1 and BX1880 seat mounts are the same? Id like to upgrade me seat without crazy modification. KM has a few good ones but only list up until 1870-1. Guessing they haven't updated yet? I can't imagine from that generation to the next would be all that different. Its not like I'm trying to put a seat in from a 20 year old machine. Anyways any input would be appreciated. Thanks!!
3,297
1,711
Their seat mounts are the same.
armylifer
Mar 26, 2013
2,224
980
Thurston County, WA
What is the difference in the seats that makes the BX1880 seat more desirable? Is the BX1880 seat mount the same as for the BX1860? How far back would a BX1880 seat retrofit?
Mrlunchbox
Nov 21, 2020
373
161
That's a good question! I want to install a KM (aftermarket) seat but their compatibility chart stops at the BX1870-1. So my hope was I could use the same mount, which it looks like I can. But as you mentioned I'm not sure how far back it goes.
Mrlunchbox
Nov 21, 2020
373
161
This is what I am looking at.
armylifer
Mar 26, 2013
2,224
980
Thurston County, WA
I looked at that one when I realized you were seeking an aftermarket solution. That one goes all the way back to the BX1800. So, it would fit every model of the BX18xx series.
leveraddict
Apr 1, 2019
905
592
NEPA
Wow! $850 and no arm rests!
lunasdude
Kubota BX1880, FEL, quick con pto, box bld, land plane, flail mower
Dec 22, 2018
55
Los Lunas, NM USA
Is there an aftermarket air suspension I can use with my BX1880 seat?
armylifer
Mar 26, 2013
2,224
980
Thurston County, WA
Here is the air suspension version of what the OP posted.
3,297
1,711
You have made my day!!! I bought my BX in September and have been looking ever since and haven't found anything other than custom jobs. Thank you very much!
Both the BX1880 and BX2370 use the same slide rails and it appears there is where it mounts. The new seat should bolt right on, but:
I did notice that the seat you are looking at lists fitting both the BX2380 and BX2680, but not the BX1880.
You might want to call them and enquire about why, as there may be another reason it will not fit a BX1880.
Mrlunchbox
Nov 21, 2020
373
161
Thank you. I did not call, but emailed. Got the standard response of its not listed it wont fit. But all the mounts are the same so who knows. I may just try it out and see how it goes.
lunasdude
Dec 22, 2018
55
Los Lunas, NM USA
Thanks, I was actually hoping there was a suspension kit that would retro fit my current kubota seat with arm rests.
$847 for a seat without arm rest is IMHO a lot of money.
Just me of course but Damm!
armylifer
Mar 26, 2013
2,224
980
Thurston County, WA
Something happened wrong in that link. It was supposed to go to the air suspension seat but defaulted to the mechanical version. The air version is $1287.00
