xrocketengineer
I have zero practical experience with diesels and I noticed today a lot of oily black soot on the left front corner of the frame and around the exhaust hole in the plastic grille after use (95hrs). I don't remember this happening before since I hose down the tractor after every use. The tractor had not been used in about three weeks with a couple of cold snaps in the 40's in between and the weather was around 70 degrees. It mowed fine with no black smoke except the usual little bit at startup and when changing RPM's. Anything to be concerned about?
