Harbor Freight quick hitch on BX 2350 (UPDATED)
bearskinner
Sep 1, 2014
926
242
N. Idaho
Yeah, it’s only 25 degrees here. Nice and crisp out. It’s been a while since I added the top hook extension. I guess I made lots of spaced out attachment holes, to more fine adjustment of the hook. Didn’t need a third bolt, but my motto is “Over Kill is Under Rated”
SpokaneDude
BX2350, FM 125 tiller, Land Pride blade, BotaProducts fuel & HST filter mods
Oct 24, 2020
92
Spokane, WA
I made the modification (see image) and I also ordered a new upper hook that sticks out about 1/2" or so, which will do the trick. Thanks for your help and suggestions, very much appreciated.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Interesting, feel free to include your fix to this post. LP blade # and a wider image also appreciated.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
So the hook wasn’t clearing the back wall of the implement? I thought the problem was where the hook bolts up.. QH bumping into implement. I have one coming for Xmas so I’m trying to get it all figured out.. and I do have the Land Pride rear blade that might have the holes set back too far, not sure yet. BF741DB0-9780-480A-95C1-08CECAF04481.jpeg
SpokaneDude
Oct 24, 2020
92
Spokane, WA
Hi Krush... no, the problem was that the hook was not clearing the back wall of the implement, so I got out this am and cut it so it would clear... that worked, but the upper hook is still too far back, so the new hook should remedy that... won't be here until after the Holidays, so I have to plow my driveway (250 ft gravel/dirt on a fairly steep hill) as it is... I called Harbor Freight and spoke to one of the tech guys and he thought as long as the lower hooks are in and the latch handles keep them in, I should be OK until the larger upper hook is installed.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
I believe the HF hitch is similar if not the same as the Northern Tool QH that I have. I had to hit the top hook with a grinder for a bit to open the hook up enough to let my LP BB1260 seat right. The top hooks are known to be a little too tight........ not sure if you encountered that but I figured I would throw it out there.......as others will hit this thread using "search" and the more solution options the merrie
SpokaneDude
Oct 24, 2020
92
Spokane, WA
Hi River... yes, I agree... I just decided to take the easy way out for me...
SD
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Does anyone here know the exact size or what best works with the HF QH top hook.. bushing wise? I was at TSC and picked up two bushings, one slides into the other if needed. I got both because I wasn’t sure.. The large one is a little too big and the other which is 1 1/8” OD is a little lose but as far as I know it may be as good as it gets. I’m not sure if they have a 1 1/4” OD that fits.. I can always shave a little off the hook inside if I need to for the larger one to fit.
armylifer
Mar 26, 2013
2,289
1,059
Thurston County, WA
I chose to shave a little off the inside of the hook. It did not take too much work with a file. That worked very well for me.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
I think that’s what I’ll be doing, I might even go at it with my lathe.. if I think it will leave enough meat on it to still be secure. Thank you sir!
OrangeKrush
Nov 15, 2020
1,044
517
Indy
River19
Sep 10, 2020
351
665
NH/VT NEK
As I mentioned earlier in the thread.....hit the hook with the grinder and open it up, there will be plenty of steel left for strength......
