Recently started working on restoring a 1979 Trans Am, however, the car is in fairly rough shape and neither door will open and the locks will not rotate. I was able to get into the car by using a hanger to open the Passenger Side T-Top and then climb in through the roof. I have the interior door panel off and can see the mechanism.
Only the horizontal rod moves when pulled on so I think the rotating mechanism that converts horizontal movement to vertical movement (and that connects the exterior handle and interior handle) is rusted solid. I'm going to be trying to spray some PB Blaster into the door this week but I am curious if anyone on here knows if the mechanism is supposed to pull up or push down to release the latch. I would think ,up but I've been wrong before, and would prefer not to have to cut a hole in the door because I broke it worse.
