I’ve had a 6200 with what I believe a bad HST. I’ve tried quite a few different things and it still acts up. After giving it hell before during and after all my attempts to fix it, I’m chocking it up as a loss....for now.
I found a 4200 manual trans in PA that I picked. The seller threw in the frame and back fiberglass with it.
My plan is/was to mate the manual trans to the 6200 motor. Well, I mounted the rearend and trans to the 6200 frame. Most everything on these tractors is the same thru the generations, however, the 4200 had the 2cylinder engine that actually didn’t sit as far back as the 3 cylinders. Also, the driveshafts are different lengths, and the couplers are sized differently.
So, as of now, it’s a rolling project. Have to measure the shaft lengths and then find a welder that can do it for me.
