What kind of side work were you going to do?
Some considerations if you are planning on side work.
Will you be working on grass/lawns or needing to drive on grass to get to the work?
Will you be driving on septic systems?
Will you be operating near houses/garages/vehicles and people?
If yes on those the 2501 will be better suited.
Doing side work and do you want a cab?
Will you be needing to communicate with customers/people while on the tractor?
Will you want maximum visibility?
Will you need to maneuver around trees a lot?
Will you be needing to get on and off a lot?
Do you have a garage or shop you need to fit into that a cab would hinder?
If yes on those, you would be better off without a cab.
I do side work with a tractor and personally, I would never have one with a cab mainly for the reasons listed above. I still do snow removal in the winter (plow and pusher) and that can be cold, but we also go out and snowmobile in it, so cold is a relative thing. I do have a ROPS canopy with a fan mounted for sun/cooling that tends to keep the bugs off and that would make a nice addition to the 2501. I tend to do a lot of lawn work and work around houses and driveways so for the type of side work I do the cab and weight would hinder me in a lot of situations.
If you are going to be doing mostly field work get the Grand 60
Side work is completely different in that it isn't about your needs, but the needs of the person you will be helping. So I have to go back to the first question,
