Adding Rear Hydraulic Remote to L3240 - Part # ?
farmboykj
G5200 ; ZD326
May 16, 2016
Central, Indiana
I have a L3240 with the standard glide shift transmission that I would like to add a rear hydraulic remote to. I am wanting to purchase the factory set-up that installs under the seat. This is for a tractor without a cab. Does anyone know the part # for the complete package that I would need for my tractor? Thanks for any information.
Schmitty
L4740, grapple, forks, box blade
Mar 25, 2018
62
37
Madison, WI
Where do you plan on buying this from? Messicks/Coleman or local? Either will be able to get you the right parts through the whole goods dept. My L4740 looks like it has the same parts needed as yours. I got the base (p/n L8335 aka TD170-98151) and a float valve (p/n L8309 aka (TD170-98161)). You could get a non-float valve, instead (p/n L8308 aka (TD170-98171)).
I also got the second position kit (p/n L8336) and a second float valve for about $1,400-1,500 shipped.
All this info is on the illustrated parts website through Kubota: here, under the "OPTION" drop down in the T15000 and T15001 sections. There may be slightly different parts needed, depending on the year or version of your tractor, so have your S/N handy if you call a dealership.
farmboykj
G5200 ; ZD326
May 16, 2016
Central, Indiana
Thank you very much. This helps a lot!
Bart Swearingen
L3240 Tractor with LA514 FEL
Nov 5, 2024
9
Germantown WI
Hay Schmitty,
Hay Schmitty, thanks for posting this. I also have a 3240 and am looking for a rear remote. I found the TD170-98151 Base Remote. If i purchase this "KIT" will it give me one hookup at the rear of my tractor? It looks like the base remote gives you one, then 2 more could be added. I don't really need more than one, but a float valve might be nice.
Schmitty
Mar 25, 2018
62
37
Madison, WI
Hi Bart,
That base kit is only half of what you need. It contains the base, lever, and coupler parts. You still need the float or non-float valve. Messicks was very helpful when I called their whole goods dept. (y)
I have not checked for differences between the two, but you will want to be sure if you have an L3240-1 or L3240-3 before calling Messicks or have your serial # handy.
Bart Swearingen
Nov 5, 2024
9
Germantown WI
Hi Bart,
Bart Swearingen
Nov 5, 2024
9
Germantown WI
Schmitty is the MAN!! Using the information shared I was able to get a rear remote on my 3240. I searched the internet for a while until I stumbled onto “new old stock” for the base remote, then got a valve from messicks and diagrams on Kubota site. All installed and operational in one afternoon. Base remote $310, valve $345.
6,973
Thats a good price. Messicks wants $955 for the base and 1sr valve.
