First time in this forum and I've got a question about this Kubota ZG327A. I just read that a recall was issued some time ago for a faulty carb. This model has only 70 hrs and is a 2014 model. It had its 50 hour checkup and oil filter change which happened to put on with a filter wrench instead of hand tighten. So I pulled the plug and nothing but fuel started to fill the drain pans. I can't be sure if someone deliberately done it to get the machine for a cheaper price. I read also that there might be up to 4 fuel filters on these machines? I can't seem to locate the carb on this machine unless its right in the center under the radiator hose?? Thanks for any advise
