Installed a new hydraulic top link today.
S-G-R
LX3310
Jun 17, 2020
1,115
2,259
PEI Canada
Nice setup! What brand did you go with and is it on your B2650?
6feettogo
B2650
Apr 22, 2020
82
51
Newman Lake, Wa
It is a AMA USA from Tractor Supply. Had to reverse the double pilot operated check valve and rotate it a 1/4 of a turn to make it so that it wouldn't hit the tractor when the 3 point was lifted all the way up. It is on the B2650.
6feettogo
B2650
Apr 22, 2020
82
51
Newman Lake, Wa
View attachment 49125 I kept mine on top and it works great. you will bw happy you installed it. View attachment 49125
I noticed that you have the top hydraulic link in the bottom hole on the tractor. Have you had any problems with it hitting the PTO guard when you put the cylinder all the way out? i noticed that the manual says you should use the top hole in most cases.
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
You could install cylinder the opposite way
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
look again cylinder on QH ram on tractor
Dae06
170
11
Minnesota
Nice, I just installed a rear remote off of my 3rd function valve but don’t have a top link yet but am considering TS’s. Did you get the hose kit from them as well?
6feettogo
B2650
Apr 22, 2020
82
51
Newman Lake, Wa
I actually got my hoses from a company called North40. A little cheaper then TS. The adapters came from a place that deals in hydraulics.
Dae06
170
11
Minnesota
Installed a new hydraulic top link today. Didn't turn out too bad. And surprisingly I didn't have any leaks.
Dumb question, to turn the cylinder 90 degrees, it must rotate at the end attached to the tractor. I didn't think mine would rotate and was permenently welded, but I may not have tried hard enough to twist it.
NHSleddog
B2650
Dec 19, 2019
2,149
1,831
Southern, NH
One side is welded solid and will not turn. The piston end will.
hope to float
L3450
Feb 18, 2018
474
61
Ireland
The one I have is too light for the abuse I give it and was weld repaired before I got it. But I hope I never have to go back to the old solid type. Sometimes I put it on the tow hitch and use it for pulling roots but those times I wish it was longer :rolleyes:
Rickklem
21
Alabama
I am in the process of adding a rear remote using my front third function . I have a diverter valve coming this week. I will need a set of hoses to connect from the diverter valve to the third function valve and another set of hoses to run to the rear. What did you use for these two sets? Does someone sell a set all ready made up or do I need to have them built at a Parker store?
