Advice needed
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
For cutting grass due to weight I suppose. It will outclass the BX for all other types of things. The BX is smaller, of course, so it can fit in tighter areas if that is a concern.
BigG
Sep 14, 2018
1,953
774
West Central,FL
That is a lot of tractor for 2 1/2 acres. And you had several trees in your yard. That means there is still going to be a lot of push mowing to trim up that yard. If money is not a problem then buy it with the idea in the back of your mind that you can sell it in order to go smaller.
If you look at TractorHouse.com the price looks about right. If you look at AuctionTime.com you will see that it is way over priced.
If I were in your shoes I would keep shopping for something smaller and better at mowing. Check our the Kubota build a tractor and you could get a new tractor closer to the size you need w/ the FEL. I think you would be much happier.
Do you have a place to keep that big of a tractor?
Besides Pittsburgh to Athens is a pretty good haul over some pretty good hills.
JimmyJazz
1,272
805
Pittsburgh, Pa
If the choice is BX or this... THIS!!!
Thats how I feel. Depending on purchase price it may represent significant value. A new set up like this would cost almost $30,000. These "Grand Series " tractors are more complicated, lots to go wrong. So far not a lot of complaints though. Thanks
JimmyJazz
1,272
805
Pittsburgh, Pa
It should fit in half of my 2 car garage. Much to my wifes dismay. 3 hrs to Athens, OH. Would you recommend a B2920? Thanks
PaulL
2,668
1,653
NZ
A new B2601 is all you need. Actually, a new BX2380 is all you need. Of course, if all we had in life was what we needed, life would be very boring.
At the want end, I genuinely believe you'd be happier with a B2601 or an LX2610. It's more "right sized" for your property, it'll do most of what the L will do, but it's lighter, will probably mow better, and it comes with a warranty.
A B2920 is also a great machine in that similar size, and would be a lot cheaper than a new B or LX. A bit more power too - pre-emissions means they're not detuning the engine down to 26HP.
It's not that an L is too big - there's not really such a thing I guess. But when you have that size property, the number of things an L does better is quite small (and mostly that just means faster, not better), and the number of things an L does worse is long (because it's a bit big for the spaces, a bit heavy for the lawn etc).
I'm a strong believer in buying what you want, but it seems like it isn't really that you want a machine that size, you're just hooked on getting more for less money. Shop around, you will find a cheap B and that's better buying for you.
JimmyJazz
1,272
805
Pittsburgh, Pa
Beautifully said. I agree. All of my life the inner poorboy is looking for a deal first. I will take your advice. Thank you!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,963
2,421
Near Lancaster, PA, USA
Near the end of 2018 we bought a clean used L4240HSTC. Loaded grooved R4's and a 7-1/2' rear mower. Best lawn mower I've had for our 3.5 acres. Happy with the 8' snow plow. Why not?
old and tired
1,919
1,297
Value is mainly what I look at but realistically, that Grand L is over the top for mowing a small area. The biggest issue I see is the total weight, hauling it around and mowing.
Hum, I wonder how far is Ohio? :unsure::ROFLMAO:
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
This is one of those go sit on it and drive it, and various other choices, around. The L40 series are good tractors. The university had one for sale at surplus,,and I was surprised at how small it was! It had been used to clear sidwalks and salt on campus where maneuverability would be necessary. This is relative to the recent grand Ls, eg my L3560. I quite happily mow an acre of lawn with trees and flower beds with a B2650 and plow and carry stuff around the yard with the L3560 and loader. Both have loaded tires. They don't tear up the lawn unless I forget and turn too sharp in 4wd. It all really depends on your yard and preferences.
chim
Jan 19, 2013
2,963
2,421
The L4240 is the largest tractor I've had to date, but handles like it's the smallest. Check actual measurements in Post #12 in this thread:
JimmyJazz
1,272
805
Pittsburgh, Pa
ISSUE RESOLVED, Well I just spoke with the seller and the height with the ROPS folded is 81 inches and the seat height is 68 inches. My garage opening is 80 inches. That tractor needs a barn. A bit disappointed. Thanks everyone for the advice.
7,264
Yes, but you'll have a happy wife! It sure is a nice tractor though, and the last version of minimal EPA requirements moving forward.
Be thankful you never set in the seat and operated it, or hooked up an implement. It would spoil you from the other models you'll find.
JimmyJazz
1,272
805
Pittsburgh, Pa
New Turf tires would lower the overall height... {where's the icon "stirring the pot"?}
I am having a hard time shaking the idea. In addition to it possibly being a stupid purchase , how stupid would it be to keep it outside/out of sight under a tarp year round? This might both please the wife and quell my diesel addiction.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
I don't like that idea. Too nice a tractor to be leaving outside with a tarp over it. You'll be inviting rodents and trapping moisture. Perhaps if you built a small shed with a proper roof and ventilation, that would be OK. Fortunately, I have a barn for mine. I would assume the winters would be hard on equipment left outside up there, just like the summers would be here. But, year round outside is just rough on anything anywhere, especially since the newer tractors have so much plastic now compared to the older machines.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Edit- I read previous post wrong
PaulL
2,668
1,653
NZ
For my view, I still think you're attracted to the deal, not to the tractor.
If you actually want a tractor that size, then absolutely. There are a few ways to make it fit - nobody will recommend it but you can cut the ROPs down a bit, or notch your garage, or build a lean-to behind the garage, or build a new pole barn (using your new tractor).
But if you're still just attracted to the deal, rest assured that another deal will come along, there's no deal so good that you can't walk away from it. If you actually want a B-sized tractor, then wait for a deal on a B-sized tractor.
5,969
re: how stupid would it be to keep it outside/out of sight under a tarp year round?
Well I've tossed wife's 2019 car OUT of the garage to put MY 2018 BX23s IN... and I'm still alive to tell you about it. A semi proper lean-to is much better than a tarp as it'll withstand Ol' man Winter, well, should.
JimmyJazz
1,272
805
Pittsburgh, Pa
There are many available now. Thanks for all the help. I will put this idea behind me. (trying not to cry)...
