pokey1416
Jun 24, 2020
567
843
SW Michigan
Installed LED’s after computing load on hazard circuit. Wanted to keep connectors in weatherproof box. Should have painted the aluminum squares but oh well. I synced all strobes and left two unterminated wires in ea. box to change pattern later. Haven’t been able to find a male connector to work on those yet. Boxes are nice but small to work in.
I tucked up wires in a loop under bracket.
mdhughes
L3901DT
Dec 10, 2014
1,320
993
Ste Geneveive county, MO
Did some more chipping and move about 25 bucket loads of dirt. I'm having a retaining wall put in, and there is a lot of dirt to put somewhere.
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
Does it display both 12 and 24 hour time formats?
No. 24 hour only. I use it primarily to count time so the 24hr format works good. I learned to use it when I was younger so it isn't really an issue for me.
Magicman
Oct 8, 2019
5,903
8,921
Brookhaven, MS
knotholesawmill.com
I have one on the way but from a different source. It looks like Amazon has switched to a different unit (Star) that may not have a USB port.
The O&A says that it can be switched to/from 12/24 hour format. ??
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
This one is 24/hr only. There were several people in the comments say it was 12/24. It is not.
FrozenOrange
L3901HST, B7100
May 8, 2017
137
56
North Pole Alaska
I finished installing my original tractor cab on my L3901. It was so nice to have a dry cab. It's. In the 30's and raining. A cab, heater and wipers. Woo hoo. No more snowblowing with an open station this winter.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Frozen Orange, beautiful place you have. That picture is a postcard type pic.
retyred57
L3901 HST, Ag tires, LA525 FEL, Landpride 66" boxblade, BE 60" rotary cutter
Aug 3, 2015
15
Ontario, Canada
Installed a precast concrete step at our camp. I was working by myself so took it very slow and easy.
Magicman
Oct 8, 2019
5,903
8,921
Brookhaven, MS
knotholesawmill.com
Thanks. That is what I kinda figured and it worked very well. The reason I asked is because I will have one to do very soon.
