B6000 3 point hitch hydraulic droop
Zoltan
Kubota B6000
Apr 15, 2014
12
Los Gatos, CA, USA
This is probably on the site somewhere but I'm not sure how to find it. My tiller on the back of my B6000 will not stay up. Is there a video or some service info how to fix this? Is this usually a bad seal that needs to be replaced?
5,257
1,046
Start with adjusting the lowering speed to see if the 3 pt will stay up or lower more slowly than at present.
This will give you some info on the condition of the 3 pt piston seal.
If the 3 pt is still dropping the next step would be replacing the 3 pt piston O ring.
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
How quick is it coming down? Is it dropping say when you raise it within say couple of minutes or say couple of hours? Is it dropping while using it?
Zoltan
Kubota B6000
Apr 15, 2014
12
Los Gatos, CA, USA
This is great info. I'll try to use the diagrams you sent to check this out. I can't seem to download them. Can you sent them to my email address? RyeL at mac dot com Thanks so much.
Zoltan
Kubota B6000
Apr 15, 2014
12
Los Gatos, CA, USA
It comes down while I'm using it. It was slow at first, a few years ago, now it's really bad. I'll check out the adjust meant as Dave suggested, and expect I'll be replacing the O rings, which is just fine, want to get this sorted out. Thanks for responding, I appreciate it.
Marc Richer
B6000
Mar 21, 2025
9
Does anyone know the inside or outside diameter of the piston o ring along with the thickness? I will find one on McMaster Carr before I take it apart. Mine is getting pretty bad, I am running the adjustment screw almost all the way down to make it somewhat usable.
5,619
Buy from a Kubota dealer.
If the lowering speed knob slows the leakdown at least dome of the leakage is in the control valve. If you close thw adjusting screw all the way does it still leak down?
Dan.
Marc Richer
B6000
Mar 21, 2025
9
If I close the screw all the way it will not go down - it goes down within a couple minutes if the adj screw is out. What do you think?
Marc
5,619
Marc
Closing the screw shuts off the lowering circuit in the control valve. If the 3pt holds the orings in the cylinder are fine. The leak down is through the 3pt control valve.
5,619
If it holds when vlosed and drops in nxa cpuple minutes when open yoy donr need an overnight test.
Unfortunately fixing the valve may be impoasible.
