Summit 3rd function on LX2610
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
This will not be a @bird dogger write up! Just some small changes from the B50 to the LX.
I do not have a backhoe, but do have 2 rear remotes.
Valve mounts to loader upright and the PB line same as the B50.
The return to tank has a banjo instead of adapter and 90. And since it is a banjo, you do not have to remove the seat tray bolt. But it does give you a bit more room. You can see the remote piping in this picture. F52C1E84-8B3D-49BC-8C51-711BFC62481D.jpeg
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
B73D6872-1C9B-4190-AA6B-E1038C624145.jpeg I added 3 more 3/8 jic 90’s, to tuck the hoses up. Will make some type of guard for the solenoids and my double 90 fitting.
That is pretty much it. I followed @bird dogger thread and it was pretty easy, minus wrestling the loaded rear tire off!
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
Will hopefully get the loader hoses installed as well as my clamp, tomorrow. Pictures to follow.
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
Got the clamp installed and hoses ran. Will order some hose cover soon.
All in all, a pretty simple install. Will zip tie as needed once I get the protective covering on all hoses.
Have to get some female wire connections to finish up the wiring. Tapped into the key power hot wire and am running to a switch on dash to energize system. May need to change that to the run side of switch, I’ll see if it has a draw or drains battery.
bird dogger
Feb 24, 2019
1,808
1,783
North Dakota
Nice job, Matt! Especially the double 90° fittings on the valve. that really gets the hoses up out of the way.
david
bird dogger
Feb 24, 2019
1,808
1,783
North Dakota
Was there any doubt? :)
Now, before you get too carried away with using the grapple, you should think about fabricating a grill guard with some expanded metal. That brush has a way of sticking through the back side of the grapple and could punch a hole in your new grill.
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
Sorta. Lol.
I am already thinking of a better guard. I should be ok for now, as I have a lot of larger logs to move. Trees I've dropped, burned the tops, but couldn’t(didn’t want to) move the logs by hand.
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
6821FB87-62F6-4EE9-8D7D-827877DBE5B1.jpeg A7B4AF15-B53B-4A41-A725-CC3521F58F24.jpeg 2AF24C2C-8214-4D19-BA8B-F111B7A0CA8C.jpeg
Got all of my hoses covered. Ordered 2 25’ 1’ID rolls. Have enough left over to do the tilt hoses if I decide to add that later on.
bird dogger
Feb 24, 2019
1,808
1,783
North Dakota
Very nice! Now you've made me want to go out and cover my grapple hoses right away! I was going to wait til later this fall. LOL!!
david
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
david
Shoulda been that way from the factory. I don’t like the very sharp bend in the lower hose either. If one pops, I will hard line into the “channel” and connect hose there.
Chad D.
255
132
Eugene
The return to tank has a banjo instead of adapter and 90. And since it is a banjo, you do not have to remove the seat tray bolt. But it does give you a bit more room. You can see the remote piping in this picture. View attachment 46089
Would sure be sweet if there was a part number for that banjo fitting on the 3-pt inlet... others have had to modify pieces to get that fitting. Do you have anything that would help direct anyone that needs that piece?
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
Let me email summit hydraulics for the parts list. I bet it’s on there and will cross, or be the same number at hydraulichoses.com
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
Here are the updated install instructions. #6,7 and 8 are the pieces that return to tank under the seat. I would suggest adding a few more #4 90* to the order, to tuck the hoses up better.
<edit by Mr. K on 12/16/2020 - copyrighted content removed per copyright holder request>
bird dogger
Feb 24, 2019
1,808
1,783
North Dakota
Matt, I used my grapple yesterday and only the hoses from the middle connection to the quick couplers are protected by sheaths. EA must have been running low on hose protector sheathing when they built my grapple. :oops: Otherwise, the hose routing looks identical to yours.....somewhat sharp bends and all.
The updated instructions are a little better on the parts identification, at least. Still would be nice if they'd add a few more pictures along the way during the installation.
david
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
david
I added all of the hose cover on mine. Atleast you got some!
I agree, that instruction sheet is by far better than what I was sent!
I sent Patrick my picture with the double 90* fittings and a suggestion to include or give the option to buy more. He said they may just start including them. Really seemed to like my setup.
dotty
2008 Kubota L3400D 4wd, 1992 Kubota B7100 HST, 1977 M-F 230 Diesel, 1949 Ford 8N
Aug 10, 2013
14
Indiana
my Summit third function kit for a LX2610 has only one copper banjo washer. how does the bottom of the fitting seal on the threaded hole? Thanks.
