Adding Coolant to Bottle
Clt1bkc
Kubota MX5400 Rops
Jun 27, 2020
36
Tigerville, SC
In my daily inspection notice the coolant bottle under hood is getting close to needing to be filled. The manual states soft water. Does make a difference wether is soft water or the coolant mix that I fill bottle with to get it back to the full line.
if it’s the mix what kind and brand do you use?
pokey1416
Jun 24, 2020
556
825
SW Michigan
Premix coolant from dealer. I can take a pic if you want.
pokey1416
Jun 24, 2020
556
825
SW Michigan
My manual says fill to between Full and Low line.
pokey1416
Jun 24, 2020
556
825
SW Michigan
This is what my local dealer carries.
SDT
multiple and various
Apr 15, 2018
3,255
1,042
SE, IN
It makes no difference.
I use full strength anti freeze to add small amounts to the overflow bottle.
I use 50/50 full strength antifreeze and distilled water when changing coolant.
SDT
3,554
2,019
Don’t use tap water even if it is softened. Buy distilled water or premix coolant. Softened water can still contain minerals and can leave you with a radiator full of gummy mess.
Pau7220
Aug 1, 2017
785
278
Scranton, PA
Agreed. Kubota specs ethelyne glycol (green) antifreeze (Zerex, Peak, Prestone). Premix is pricey, distilled water is dirt cheap at CVS, Walgreens, etc. Mixing it yourself cost about half the $
