Fusible Link
KennethH
L1802DT
Nov 20, 2016
14
Covington, LA
I have an L1802 similar to L235/L275. I cannot find a part number for a fusible link. Does a anyone know the part number? Thanks
5,255
1,056
While I too cannot find the fusible link searching on Messicks for the L235/275, the wiring diagram certainly shows one.
I believe they are build to a standard and part number 38430-34530 for $8.07 will work. It is a green one rated at 40 amps.
Later I searched on Kubota.ca and found the proper fusible link which has part number 3843034530 which is the same.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
549
181
NZ
You likely know this but it is possible to convert to a slow blow fuse.
I'm interested, how do you convert to a slow blow fuse - what amps and are there any advantages/disadvantages? Thank you.
5,255
1,056
Most automotive places sell the slow blow fuses. That is the benefit in that they are readily available today and modern vehicles are designed using them whereas fusible links are generally sold by dealers to service older equipment.. Otherwise there is little reason to change.
Sometimes the challenge is getting the fuse holder.
JohnDB
Jun 9, 2018
549
181
NZ
Thanks, is there any need to change the fuse rating? Or do the new slow-blow fuses blow at basically the same amps and milliseconds as the old fusible link blows?
5,255
1,056
Your green fusible link is rated at 30 amps.
Slow Blow fuses come in many amp ratings so buying the correct 30 amp one is essential to maintain the appropriate level of protection.
JohnDB
Jun 9, 2018
549
181
NZ
Thanks Dave!
6,257
Fusible links can be replaced with either fuses or circuit breakers. 'links' have been a great 'scam' to make money for equipment mfrs. Cars ran for DECADES before 'links' were dreamed up, planes fly without links....riders use fuses to protect the stator...
