New To Me B6000E & B6000D w/Loader
poconoguy17
Kubota B6000E & Kubota B6000DT w/Loader
Jul 13, 2020
106
19
Pocono Mountains
Never seen a B219 that would lift the front end with down pressure, but it should lift it with the curl function.
After a few flushes of the hydro and correct fill It has no issue lifting the front, granted not very high but a foot is enough to back drag the driveway .
3,535
Cool. Mine will lift with enough down pressure to back drag, but not a foot. But mine undoubtably weighs a lot more than yours- bigger tractor, bigger engine, PTB, front wheel weights, etc.
Maybe I should consider lightening mine. :)
poconoguy17
Jul 13, 2020
106
19
Pocono Mountains
Yep you def have a bit more weight! But hey... I am a sport and will take one for the team.... I'll give ya an even trade so you too can flex with the loader lifting the front.. no... don't thank me.... it's what I do lmao
3,535
Your screen was cleaner than mine- couldn't even see the screen material before cleaning.
3,535
You know, you're not the first to make that offer. :)
poconoguy17
Jul 13, 2020
106
19
Pocono Mountains
Here is a couple of pictures View attachment 45881 View attachment 45882 of my 6000DT. I have a belly mower but they are a pain. I have Woods RM48 but I have a reverser for the PTO. By the way the PTO turns counterclock wise on B6000. Woods did make a RM48 for the counter clockwise PTO. I saw one on Craigslist several months ago. You are somewhat close to me and if I remember it was up your way. By the way, get the operating manual and the parts list. They are avaliable online to download. Feel free to ask questions. I had a B6000 since at least 1977. I would go with turf tires on grass. I use mine in a swampy field. Millers in Ohio has them.
What rear tires do you have on yours? I spin so bad with my bald truck tires and would rather use something like the ones you have (similar to the ones of my borrowed BX-25) which , when dry haven't torn up the lawn and offer'd great traction uphill.
3,535
Carlisle Farm Specialist, 7.50 x 16.
3,535
That's the size that is stuck in my head, but I will verify sometime today.
3,859
2,394
Could just be the picture angle, but those 3 pt arms on the dt sure look long! That could be an advantage when carrying a counterweight for the loader, but might make interchange with the other one an issue. Are they the same?
poconoguy17
Jul 13, 2020
106
19
Pocono Mountains
I think its the angle and the dirt from before it was cleaned and painted. They are std cat 1 size
3,535
You were right.
8-16 on rear, 6-12 on front.
The 7.50 - 16 size was what was on the tractor when I got it.
JosephGozo
Kubota B7001 + an ever growing list of attachments (restored / homemade) :(
Nov 25, 2014
85
36
Malta
Hello, Nice finds.
Where is the hydraulic pump on the 6000DT?
Joe
poconoguy17
Jul 13, 2020
106
19
Pocono Mountains
Hello, Nice finds.
Joe
For one that drives a B219 Loader it is on the right side of the tractor on a bracket off the flywheel pulley.
W/O loader the one that drives the trans is on the left side under the exhaust manifold.
JosephGozo
Nov 25, 2014
85
36
Malta
Thanks I was interested in the location of the B219's set up. I do not have space for a belt driven Hydraulic compressor. Is it it he standard Cessna pump that sits on the front?
poconoguy17
Jul 13, 2020
106
19
Pocono Mountains
Yes it is... It's a small pump and fits nicely in there. I would imagine if you can fabricate (or have someone fab one) you could locate it elsewhere .
JosephGozo
Nov 25, 2014
85
36
Malta
i am having a splined bush made to match the crank pto. :)
