6,372
OKAY!!! I'm definitely going to need some more info and details on your cherry picker. That is way cool! So many uses popped into my head on ways to utilize that. Lol.
Yep, IBC tote frame. Check out FB marketplace. I got mine for $40. I would say get the 275 gal frame. Just know that the "floor" of the totes are sloped so, you may have to add some "flooring" to level it off and to cover the sheet metal so it isn't so slippery.
Mine is the 330 gal. Since the basket is so tall, I added a modified pallet to the floor. Alternatively, you could always cut off the top rail to reduce the height.
One additional caution. Be careful in clamping the basket to the loader/fork frame. make sure to camp it to the fork frame only so that when you are curling/dumping the forks, you aren't putting more pressure on the clamp/strap.
added a saw holder to mine as well.
3,368
Used the PTB to take a couple scoops of gravel/dirt from the uphill side of the county culvert. Keeps dirt/gravel from being washed into my watercourse during monsoon rains. (coming soon)
Piercencg
L4701
Jan 3, 2019
Franklinton
I attached a double 12v fan above my head on the ROPS. Keeps my head and neck cool. Also installed a hand crank siren on my canopy just because its fun.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
Nothing today.
I got into some Mock Oranges so I guess one of them got into a tire. This tire is old so it will get replaced. $122 + +. The tire shop said that it will be ready tomorrow.
3,777
Have not tried any of those yet. I do like the larger gauges for tractor time. a bit of cigar smoke mixed in with the diesel exhaust keeps the bugs away
Very appropriate answer to him!
Yes, but I’m willing to bet you had to “Google” it. 🤣
Magicman wrote: “I got into some Mock Oranges so I guess one of them got into a tire.”
I am not familiar with “Mock Orange” so I Googled and found none of the species mentioned thorns....
Magicman, can you elaborate what a “Mock Orange” is and/or show us a pic of what caused the tire damage?
3,777
Geo. some people are so full of themselves they could strut while setting down!
Ahhh...I see.... Thanks for demonstrating.
3,777
I am not at my property and can not get a photo, but Google found them. Add "thorn" after mock orange.
Mock Orange
They have horrible thorns.
HARDY Orange.... OK... Thanks!
“The Hardy Orange (Poncirus trifoliata), also known as Bitter Orange and Trifoliate Orange, is a deciduous shrub often used in hedges. Sharp, 2-inch-long thorns protrude in great numbers from the twisting, dark-green stems, making hardy orange hedges almost impassible....”
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
Well OK George, and I knew that. Mock Orange is the most used name here for this awful pest.
Apparently different animals eat the fruit just as they do Persimmon and pass the fertilized seed through which causes it's spread. Thankfully they are shallow rooted and the FEL will scoop them up, but the front tractor tires are sometimes exposed.
UpNorthMI
May 12, 2020
849
567
Up North, MI
Relocated my L3901 tractor today from home garden duty to woodland food plotting, getting ready for a few weekends of work with food plotting, I round up a couple of friends and try to have a tractor set up for each key operation, spreading, rototilling, cultipacking etc. Also trailered three 20' culvert pipes, going to be digging them in over the next couple of weeks as things finally dry out for the summer, hopefully water will flow better next year.
hope to float
L3450
Feb 18, 2018
490
61
Ireland
I often see "Food plot" mentioned here. Originally, I thought it was somewhere people grew food to eat. Now, I'm not so sure. Could someone explain please?
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
Generally it is a small area with planted feed for wildlife.
Here, it is mostly for deer. They love clover etc.
johnjk
Apr 13, 2017
1,717
1,969
West Mansfield, OH
Changed out the original fan belt on the B1700. 3 bolts, one on the exhaust pipe and 2 on the dynamo. Total time 15 minutes.
3,368
You must not have the crankshaft driven FEL pump. Lucky!
