How big a brush hog on a mx5200
zxcvbnm
mx5200
Nov 18, 2018
10
Springfield, MO
Currently using a 7 foot mounted bush hog. Owners manual says max is 7ft mounted or 8ft pull type. I mostly cut tall & thick grass & weeds. Anyone using a 9ft mounted cutter?
SidecarFlip
Banned
563
I run a 12 foot bat wing with my M9, no issue. I also have a LP 8 foot single spindle and in thick stuff it works it a bit.
I'd say you'd be pressed in heavy stuff. with a 9, you have about 20 less horses than I do.
SDT
multiple and various
Apr 15, 2018
3,423
1,197
SE, IN
No chance.
I use a HD 6' mounted cutter with my L6060 and it is often all it wants.
Relatedly, I've never heard of a 9' mounted single spindle cutter (never heard of an 8' mounted single spindle either) and would be interested in learning about either even though neither makes much sense.
Links?
SDT
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I am not familiar with a single spindle cutter wider than 7'. When I bought my Bushhog 3008 (2 spindle 8'), I was advised that it would be easier than the 7'. The 3008 is ~20 years old and I have always been satisfied.
SidecarFlip
Banned
563
No chance.
Links?
SDT
Try Landpride's website. the RC model I have is on there.
SDT
Apr 15, 2018
3,423
1,197
SE, IN
Didn't try the website but did look in my current LP hard copy catalogue.
I found 7' single spindle cutters but no 8' models and certainly no 9' models. The Woods BB840X 7' cutter that I recently sold was LONG. I cannot imagine an 8' single spindle model, let alone a 9' model.
SDT
SidecarFlip
Banned
563
SDT
I'll go get the model number right now...
RCF 2784 Pradon me, it's a 7 footer, smooth top and it's heavy.
SDT
Apr 15, 2018
3,423
1,197
SE, IN
Bingo.
My Woods BB840X was heavy as well (and long).
I cannot even imagine an 8', let alone 9', single spindle cutter.
SDT
BigG
Sep 14, 2018
1,953
774
West Central,FL
I would think the amount of wear and tear a 8 or 9 foot would do to itself make them impractical. There would be an awful lot of twisting forces on the 3 point as you move across a field. Plus the great length would cause problems as you crossed ditches and humps that would lead to a great deal of scalping. I have a Rhino 96 that has 2 spindles that you must pay attention to or it hits the ground often. And the cutting area is only 4 foot compared to 8 or 9 foot.
A 2 spindle unit it much more practical as far as the physics of pulling it across a field.
There is a 10 flex mower built by RhinoAG a TS 10, that is rated at a very low 25 horse that might work. It requires only one rear remote. If I had a lot of pasture to mow I think I would look into one of these. As I think the fixed 10 foot mower are harder to get through gates and to transport on trucks.
The MX5200 would make a good fit to pull it.
At 3 mph:
6 foot 1.96 acres per hour
7 foot 2.29 acres per hour
10 foot 3.27 acres per hour
SDT
Apr 15, 2018
3,423
1,197
SE, IN
At 3 mph:
Agreed, BigG.
I bought a new Woods MDS1260 mounted (either/or semi-mounted) twin spindle 10.5' cutter in 2008.
Never liked it and sold it a couple of years ago with less than 100 hours.
Since then I've owned a Woods BB840X 7' single spindle cutter (since sold) and now own a Woods BW 15.50 15' BW.
Didn't like the 7' mower and have serious reservations about the 15' BW but the jury is still out.
Really wanted the new LP HD 12' BW (no, not the light duty model) with optional ORC, but it would have cost nearly $3,500 more than the 15' Woods model that I bought with 8 tires rather than 6 (max) on the LP.
Time will tell.
SDT
psdstu
M7060HDC, L4060 HTSC, B2601, RTV1140
Dec 20, 2015
38
11
Marianna
Agreed, BigG.
Time will tell.
SDT
I have the LP 3712 with 6 tires and the ORC, Its a great cutter and I have been very pleased with it!
SDT
Apr 15, 2018
3,423
1,197
SE, IN
That's the model that I wanted. I know of no other BW that is offered with a built in ORC.
I could have used a 3712 with either my M9960 or my L6060 (only with swivel hitch), but simply could not justify the price.
SDT
psdstu
Dec 20, 2015
38
11
Marianna
SDT
Agreed it's pricey, but with the 6 tires, ORC and High Performance Hitch it has been a great cutter. I have heard of someone who Flipped the High Performance Hitch in order to make it work with there L6060.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I have my 3008 Bushhog on a semi mount;
i/e lift arms on the front and wheels on the rear.
Hydraulic cylinder controls the rear height.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
A 8' dual spindle is easier to handle than a 7' single. I have a 3008 bushhog and it's been a very good cutter. I haven't used it in several years since moving up to a 15' batwing. I can't imagine you being able to handle more than a 8' with a MX.
