M5030
Bigmoney$$$$$
M5030DT
Jun 16, 2020
Kentucky
I just bought a 5030 with a problem it is white smoking and running hot I put new injectors injector pump lift pump change shims under pump nothing has help it runs around 200 degrees I have checked compression it’s 350 to 400 on all cylinders it has no blowby does anyone know anything else to check
SidecarFlip
Banned
562
Radiator clean? Water pump working properly? Fan belt tight? Thermostat and rad pressure cap good?
kkk
Banned
rtv900 /u15 ex/WP 955/woodmizer LT15
Apr 10, 2020
47
OreGun, BLM
Isn't white smoke a sign of water?
Seems like my old ford 6 liter had this issue.....
Perhaps a head gasket or worse...idk
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
474
110
NZ
Getting a workshop service manual for the engine and reading the troubleshooting section would be a good start. If you're planning to keep the tractor for any length of time you'll be pleased you got it. Try Ebay, kubotabooks.com, or any one of a number of document sites like Scribd, your dealer or Messicks or Colemans.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,275
177
Coyote Flats,Texas
Welcome to OTT
350-400#s compression should be sufficient. Did you notice much difference in #s of comp. per cylinder? Did you pop test new injector's before installation? Were new injectors OEM or aftermarket? I suggest in lieu of just adding/removing IP shims to attempt to time IP correctly. IMHO engine operating at 200° isn't operating "hot".
Bigmoney$$$$$
M5030DT
Jun 16, 2020
Kentucky
Welcome to OTT
I had injectors pop test they are after market I talked to dealer there where the ones to tell me to try moving shims around said there was no real way to know how they should be but to try moving around and is 200 in normal for that tractor
7,148
If you reduced or added shims under the IP you changed the timing. I'd be putting it back as it was. Might pressure test your radiator to see if it is losing fluid. Is the white smoke continuous? I'd guess head gasket leaking.
SidecarFlip
Banned
562
+10.. White exhaust is usually indicative of a head gasket issue. Never fool with the pump shims. Whoever told you that is a shoemaker.
BigG
Sep 14, 2018
1,951
774
West Central,FL
I have had a diesel GMC that has blown white exhaust three times. Each time it was a bad injector. Yes water produces white exhaust but it is not the only cause. Find someone who knows how to set up the pump and injectors. I would take the wolfman's advice and buy OEM injectors or the repair shop he recommends and spend the money for a pro to set up the system.
7,148
If you confirm your cooling system is in proper order, next step would be injectors. Aftermarket injectors are usually not worth the trouble. It usually entails a lot of practice removing and installing the parts because what you think will solve your problem doesn't, so you have to remove them and start over.
Here's where I'd suggest purchasing injectors. They have excellent service, quality and timely shipping.
SidecarFlip
Banned
562
Or a Kubota dealer but be apprised, they won't be cheap.
Bigmoney$$$$$
M5030DT
Jun 16, 2020
Kentucky
8918018
M6040, M5030DTSU, L2850,
Jun 4, 2017
19
CT
Old post, but since you didn't way what you found, you could loosen each injector line nut one at a time and see if cancelling out that cylinder changes anything, maybe one bad one?
