B1600D Operating
Jrivas13
12
Ct
Hey I just brought this B1600D home recently and looking for some information on some unknown levers. Anyone know off hand which each does? or any manual I could find?
Buse
B6100 with FEL
Oct 3, 2011
40
Sweden
Hi Jirvas, good buy!
I got my B6100 late sept and invested in a CD "Kubota B51/61/71 Operators & Maintenance Manual. In my view it was a good spent 14 Euros...Any particular levers your thinking of?
Jrivas13
12
Ct
Hi!
Are you talking about a B1600 or a B6100? If you need some information about the B1600 maybe I can help you. I have a B1600DT.
I am talking about b1600dt. I mean just looking for maybe how the locker pedal works, is there a 4wd lever, etc there might also be one under the seat aswell.
Michbeck
B1181, G23 HD
Sep 29, 2011
80
Austria, Upperaustria
There are two levers under the seat. When you are sitting on the tractor the lever on the left under the seat is for the 4wd drive. Lever in forward position - 4wd off. The lever on the right side under the seat is for the gear reduction.
With locker pedal you mean the pedal for the diff. lock? When you want to use it, make sure you only go straight forward, lower the rpm of the engine and then push the pedal.
Jrivas13
12
Ct
Perfect thank you. Did you ever happen to find a manual for this model? I did some google and eBay searches and came up with nothing.
Michbeck
B1181, G23 HD
Sep 29, 2011
80
I don't have a real manual either. I've got some data sheets with the most important information, such as oil levels and oil capacity and operating information.
If you want I can scan it and send it as .pdf.
