I am talking about b1600dt. I mean just looking for maybe how the locker pedal works, is there a 4wd lever, etc there might also be one under the seat aswell.Hi!
Are you talking about a B1600 or a B6100? If you need some information about the B1600 maybe I can help you. I have a B1600DT.
Perfect thank you. Did you ever happen to find a manual for this model? I did some google and eBay searches and came up with nothing.There are two levers under the seat. When you are sitting on the tractor the lever on the left under the seat is for the 4wd drive. Lever in forward position - 4wd off. The lever on the right side under the seat is for the gear reduction.
With locker pedal you mean the pedal for the diff. lock? When you want to use it, make sure you only go straight forward, lower the rpm of the engine and then push the pedal.
Yes please could you? Send it to joe.rivas13 (at) gmail.comI don't have a real manual either. I've got some data sheets with the most important information, such as oil levels and oil capacity and operating information.
If you want I can scan it and send it as .pdf.
If anyone still has access to these sheets I would really appreciate it as I just bought a B1600D as well.Yes please could you? Send it to joe.rivas13 (at) gmail.com
