Fuel Tank Strainer
havebikewilltravel
B3300SU HSD/LA504/LandPride FDR1660
Aug 15, 2015
9
Ponca City, OK
Would someone who owns one of the models listed below mind measuring the ID of the fuel tank fill neck on your tractor (to the nearest 1/16”) and posting that in a reply?
My model did not come with a tank inlet strainer, but supposedly these did. I’d like to determine whether the strainer for those would fit my fill neck.
Thank you in advance!!
(This is from Messick's website.)
The part fits the 47 models listed below:
B4200D (4wd)
B5100D-P (4wd)
B5100E-P (2wd)
B5200D (4wd)
B5200E (2wd)
B6100D-P (4wd)
B6100E-P (2wd)
B6100HST-D (Hydrostatic Transmission, 4wd)
B6100HST-E (Hydrostatic Transmission, 2wd)
B6200D (4wd)
B6200E (2wd)
B7100D-P (4wd)
B7100HST-D NEW TYPE >=S / N60164 (Hydrostatic Transmission, 4wd)
B7100HST-D OLD TYPE <=S / N60163 (Hydrostatic Transmission, 4wd)
B7100HST-E NEW TYPE >=S / N20025 (Hydrostatic Transmission, 2wd)
B7100HST-E OLD TYPE <=S / N20024 (Hydrostatic Transmission, 2wd)
B7200D (4wd)
B7200E (2wd)
B8200DP (4wd) - T06400 FUEL TANK
B8200DP (4wd) - T06500 FUEL TANK
B8200EP (2wd) - T06400 FUEL TANK
B8200EP (2wd) - T06500 FUEL TANK
B8200HST-DP (Hydrostatic Transmission, 4wd)
B8200HST-EP (Hydrostatic Transmission, 2wd)
B9200HST-DP (Hydrostatic Transmission, 4wd)
B9200HST-EP (Hydrostatic Transmission, 2wd)
G3200
G3200 (Gear)
G4200
G4200 (Gear)
G4200H
G4200H (HST)
G5200H
G6200H
KH-1 10 - K02900 FUEL TANK
KH-1 10 - K03200 OIL TANK
L185DT (Dual Traction 4wd)
L185F (2wd)
L245H (High clearance)
L305DT (Dual Traction 4wd)
L305F (2wd)
L345
L345DT
L345DT (Dual Traction 4wd)
L355SS (Shutle shift)
M4500 (2wd)
M4500DT (Dual Traction, 4wd)
M5500DT (Dual Traction, 4wd)
M7500 (2wd)
M7500DT (Dual Traction, 4wd)
6,872
Strainer only catches big chunks. Just filter your fuel before it goes in the tractor.
Ditto. Just pick up some Mr. Funnel funnels. They will filter out junk and any water in the fuel as well.
Bark
L4701/FM2560LA765/BB2560Pittsburgh disk Titan P forks
Feb 18, 2020
202
55
North CA
This doesn't help you but how are you fueling it (ie 5 gal can with funnel, 55 gal drum with pump and nozzle)?
3,549
1,977
B4200D (4wd)
B5100D-P (4wd)
B5100E-P (2wd)
B5200D (4wd)
B5200E (2wd)
B6100D-P (4wd)
B6100E-P (2wd)
B6200D (4wd)
B6200E (2wd)
B7100D-P (4wd)
B7200D (4wd)
B7200E (2wd)
G3200
G3200 (Gear)
G4200
G4200 (Gear)
G4200H
G4200H (HST)
G5200H
G6200H
L185F (2wd)
L305F (2wd)
L345
L345DT
M4500 (2wd)
M7500 (2wd)
Fill opening measures 1 13/16"
07wingnut
272
120
Clearwater, BC, CA
That fuel strainer on your tank fill inlet could save you a ton of trouble down the road. It is not meant to filter your fuel at all, but to keep miscellaneous debris from getting into your tank. Do a search on this site and you will encounter numerous threads of garbage in the fuel tank, from insects to leaves, that clog up the tank outlet. It only takes a moment for this stuff to get into the tank when you have the cap off. The screen shown is permanently located in the filler neck, anything going into the tank has to make it thru the screen.
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Yup on debris falling in. First time I cleaned water separator there was an alfalfa leaf and a couple of horse hairs on it. Good idea to use funnel, strainer, and brush off coat before fueling. Avoid windy dusty days in the barn. :eek::eek::eek:
4,063
Use a piece cut out of Flip’s felt hat. Genuine felt is a great filter and catches water also. :p
havebikewilltravel
Aug 15, 2015
9
Ponca City, OK
07wingnut, if I could trouble you, what is the OD of the plastic neck on that strainer in your photo, and where did you get it? TIA!
07wingnut
272
120
Clearwater, BC, CA
Ok, I got the measurement, and this is on a 2005 kubota BX23. The ID of the filler neck is 3 inches. The screen shown, is actually a tea strainer bought off Ebay, from a chinese supplier, cut off and sandwiched in between two different diameter pvc rings. The handle was added to facilitate removal for cleanout. I hope this helps.
John T
2017 BX23S
May 5, 2017
1,251
782
under a rock
Wingnut
Where can I find a drop in screen like that?
Thank you
07wingnut
272
120
Clearwater, BC, CA
That screen is made from a tea strainer purchased from Ebay. However, a quick search did not show the original one used on the BX23, but there are plenty of other ones, one of which might satisfy what you need.
John T
2017 BX23S
May 5, 2017
1,251
782
under a rock
Thanks for the info....
also, Didnt realize you already answered my question a few posts above... DOH !
I'm off to find a tea strainer.......
3,480
If you can wait, I'll measure my B7100, but not sure when that will be.
Here's a pic:
3,480
I like the fact it keeps crap out of the tank, but it does slow the flow down when filling.
In Utopia
L175 FEL
Apr 21, 2013
659
188
Utopia,Tx/Pasadena,TX
That looks just like the one on my L175.
Takes longer to fuel, and if you're not careful you can either poke a hole in it, or push it into the tank.
