I had no problem torquing the bolts without damaging the socket. Let me measure my socket to see what diameter it is. I also have a set of thin wall Harbor Freight lug nut sockets which may be what I actually used.Two questions.....could you torque it to 96lb with that SP socket without breaking it?
And secondly I'd like to compare the diameter of the holes....mine are:
2.4 cm (24mm) or 31/32nds of a inch.
And I just noticed that you have 5 bolts to hold the spacer on. Did it come like that stock when you bought your tractor or did you have to remove the 2 studs (like I have on my BX2380) and replace them with bolts?
I assume it came from the factory with 5 bolts and no studs. It was used when I bought it.
