PTO output shaft
Boldy
Kubota L1500
Mar 16, 2020
Mortlake
Who knows if I can renew the oil seal at the back of the PTO output shaft of the L1500 without split the tracktor and whitout emptied the whole oil system
jkk04
kubota l1500, JD 410 backhoe,MF 30 tractor, IH TD14 142, BCS 715 tiller
Jan 9, 2017
79
PLYMOUTH CA
Do you need to replace the seal on back of pto shaft?(see attached pictures)
If so, it doesn't need split or remove any oil. Just remove 4 bolts on seal retainer then replace pto seal.
jkk04
https://www.orangetractortalks.com/forums/attachment.php?attachmentid=48233&stc=1&d=1586436977
https://www.orangetractortalks.com/forums/attachment.php?attachmentid=48234&stc=1&d=1586436977
https://www.orangetractortalks.com/forums/attachment.php?attachmentid=48235&stc=1&d=1586436977
Boldy
Kubota L1500
Mar 16, 2020
Mortlake
jkk04
Thanks jkk04 for the photo's , a big help
5,671
Would it make sense to replace that bearing with one that has a seal on the 'outside' only, to reduce leakage ?
