1120d starting issue
OlFerguson
4440, 1120D
Jun 1, 2017
192
11
My 1120 with the d1105 has kinda been a pain in my arse since I got it. When it runs good it’s great but right now it won’t start . I’ve changed the fuel filter with no luck. The only other thing I can think of is the small fuel lines could be plugged ? Lifter pump? Anyone else have this issue with this unit or motor ? Tips? Thanks
Roadworthy
L2501 HST
Aug 17, 2019
1,649
527
Benton City, WA
Have you checked the air intake and the air filter? Are your glow plugs getting power? Are they functional?
OlFerguson
4440, 1120D
Jun 1, 2017
192
11
My machine has 700 hours . I’d have to check the wsm for service interval , but I did check my injectors at 500 hrs and they seemed ok.
rentthis
1,007
24
38
summerville,sc
Disconnect the fuel line from the tank to the pump and check for good fuel flow. With a machine that new, I would suspect trash in the bottom of the tank. It might have just gotten to the point that the blockage is sufficient to stop fuel flow.
OlFerguson
4440, 1120D
Jun 1, 2017
192
11
Thank you. I’m hoping this helps
1,448
Have you verified the glow plugs are working properly?
